Waterless coolant
Old Feb 11, 2013 | 09:10 PM
C5RClone's Avatar
C5RClone
Default Waterless coolant
Anyone using waterless coolant?
Old Feb 11, 2013 | 10:49 PM
El original's Avatar
El original
Not sure what that is? So I will say no!
Old Feb 11, 2013 | 10:59 PM
jornahow's Avatar
jornahow
There used to be people peddling undiluted propylene glycol as a coolant. the problem is that it has a much lower thermal capacity than water/antifreeze so your motor will run much hotter. If it worked properly some manufacturers would have it as a factory fill, just to extend warranties and avoid corrosion problems; I'm a sceptic.
To Waterless coolant
