[Z06] new car question
Old Feb 13, 2013 | 07:16 PM
zeke2u's Avatar
zeke2u
Default new car question
I just picked-up a salvaged '03 Z06. It had no structural or functional damage (it appears that only the windshield needs replacing and the roof needs a bit of fiberglass work). It's a low-mileage car (25k). I ran through the DTC codes, there seems to be quite a few. I didn't get a chance to write them all down, I think there was only one PCM code, but the ABS light is on and there were quite a few BCM and others. However, my question concerns the valve-springs. The engine seems to run great, very smooth, no abnormal noises, all the fluids and oil look fine. What concerns me is the car was built early in the run - it was actually delivered, originally, to the Corvette Museum in October '02 (there's a sticker on the door and when I ran a vehicle report through my local Chevy dealer, it showed-up there, too.) Anyway, my concern is the valve-springs were probably never changed and I've heard plenty of horror stories here. I have a new set of springs in my garage that I never got around to installing in my other Z, which has ~106k miles now. I figured I'd put the question to collective wisdom that I've found on the forum - should I replace the valve springs right away (there's a lot of other issues that'll need to be resolved before the car can be retitled)?
Old Feb 13, 2013 | 08:03 PM
z06scentair's Avatar
z06scentair
Congrats on the new vette, my TR 02 was a museum delivery car as well. There were only a few hundred cars that were nursery cars.
Post all the codes and someone will chime in with answers.
Change the springs, it is not worth damaging the motor over the small amount of cost and time for the matter.
Old Feb 13, 2013 | 10:10 PM
zeke2u's Avatar
zeke2u
So, what exactly is "Museum Delivery"? The original owner only brought it back once for warranty work - new windshield, "Perform Reprogram and Functional Test, and Front floor panel carpet replacement.
Old Feb 13, 2013 | 10:48 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
The original owner picked up the car at the factory plant in KY... it never went through a Chevy dealer.
Old Feb 13, 2013 | 10:53 PM
Grimlock's Avatar
Grimlock
I'd do the springs for the piece of mind. I replaced mine and found out I didn't have the bad batch of springs, but I sleep better at night knowing for a fact that the weak springs are not in my car.
To new car question
