Having issues lowering the rear
Old Feb 15, 2013 | 11:26 PM
nickwfd92's Avatar
nickwfd92
Default Having issues lowering the rear
I just put new tires and rims on. I want to lower the rear some. Its at stock height now. The bolt just wont turn. And I dont want to break anything. Also is there any issue lowering the rear?
Old Feb 15, 2013 | 11:38 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Hit it with some PB Blaster. If all else fails cut it off. You can get longer grade 8 bolts from places like Fastenall. With longer bolts you have a greater range to lower. No problems lowering rear as long as you match the change with the front. Plenty of threads onthis topic.
Jim
Old Feb 16, 2013 | 05:00 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Just try saturating it with PB Blaster, let it soak a while and try again....
To Having issues lowering the rear
