Seat Foam Problems
Old Feb 22, 2013 | 02:02 PM
flags97's Avatar
flags97
Default Seat Foam Problems
I am attempting to put in new foam and seat covers, the first problem I am having, it looks like the foam for the seat(bottom) is way to big, the foam for the back and sides will fit fine with a little work. Also there is a hole near each rear corner of foam(about a square inch) on each bottom. So does anyone know if they had a lot of cutting to do or is my new foam wrong or am I getting in over my head. Any help is appreciated. Can't find upholsterer under $200 a seat, I was looking to pay $100 per seat.
Old Feb 22, 2013 | 02:04 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Old Feb 22, 2013 | 02:19 PM
chris308's Avatar
chris308
Default might help..
http://www.corvetteamerica.com/video...portScInstall/
Old Feb 22, 2013 | 02:22 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Corvette America had a series of videos on installing new seat covers and foam. The 2nd video shows cutting and trimming new foam.
Here's the video link and hope it helps you out.
Old Feb 22, 2013 | 02:55 PM
flags97's Avatar
flags97
Thanks for the videos, very informative. I am still worried about cutting foam. Those of you that did yours, did you do much or any cutting.Thanks
Old Feb 22, 2013 | 03:09 PM
fishbust's Avatar
fishbust
Old Feb 22, 2013 | 08:12 PM
flags97's Avatar
flags97
Originally Posted by fishbust
I did some cutting in the rear corners and on the side for the switches.
Not too much, just do a little at a time and take your time.
Make sure you cut enough off the side or you will have trouble getting the switches right later on.
Saw your pics, you did a great job!!!
Old Feb 22, 2013 | 11:14 PM
Rookieracer's Avatar
Rookieracer
I added some vinyl tubing to the areas that normally dig into the foam. A little maximum hold duct tape to keep it in place.
Old Feb 23, 2013 | 07:59 AM
flags97's Avatar
flags97
Thats a great ideal, thanks Rookieracer!!
Old Feb 23, 2013 | 10:55 AM
Rookieracer
Actually I read about it on this forum in another thread when I was researching how to do my seats. So I can't take credit for the idea, however, as far as I know, these are the only pictures that have been posted.
Vinyl tubing is from Home Depot.
To Seat Foam Problems
