[Z06] Shifters
Old Feb 23, 2013 | 04:39 PM
wmjosjr's Avatar
wmjosjr
Default Shifters
Hi, Like everything else we all have differance opions. Regarding 2004 C5 Z06 shifters. There are Hurst, B&W, MGW, they all pretty much claim 30 to 35% shorter throws, is that also the same for the stock C6 Z06 shifter? And do you have to change the shifter box like MGW requires?
Thanks,
Bill
Old Feb 23, 2013 | 05:56 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
I'm making the switch on my short shifter to an MGW. After reading both sides of the argument, i rather play better safe than sorry. So i will be replacing the shifter box on my C5 Z06 when i do the shifter swap. I've driven my buddies C6 Z06 and i can say the shifts are smooth and precise but only a tad shorter than a stock C5 Z06 shifter. But as you stated above it's all based on personal preference on what goes into one's car. I'm just waiting on my custom made C6 **** to arrive and i'm ready to rock and roll.
Old Feb 23, 2013 | 06:34 PM
wmjosjr's Avatar
wmjosjr
Thanks for the reply. In the picture, is that yours? and if so, is the the shifter box MGW or GM?
Thank you,
Bill.
Old Feb 23, 2013 | 07:01 PM
z06scentair's Avatar
z06scentair
My z06 has 35k miles, i changed the shifter box when i installed the shortened c6 tps shifter with a new gm.
Two months later i switched to a hurst just because i wanted to see if they were different....if they were it wasnt by much.
Two months after that switch i purchased the mgw and their version of the shifter box. The mgw appears to be the same design as the gm maybe cleaned up a slight amount around the casting marks.
The Mgw is nicely machined but i would not say its leaps and bounds over the other two mentioned. There was not a noticable difference in the shifter box either. The mgw and hurst were both more precise shifters when rowing through the gears.
In the end it all comes down to matter of opinion.
Old Feb 23, 2013 | 07:11 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Thank you,
Bill.
Yes, those are my current parts for my shifter swap. It's a GM shifter box with a C6 shifter on it.
Old Feb 23, 2013 | 07:42 PM
wmjosjr's Avatar
wmjosjr
Thank you Z06scentair.
Old Feb 23, 2013 | 07:49 PM
z06scentair
No problem
Old Feb 24, 2013 | 02:13 AM
TGz06's Avatar
TGz06
After plenty of research I went with the MGW. I say money well spent. I heard plenty of people bash hurst and the c6 shifter swap. I haven't heard anything bad about MGW. They only recommend you change the shifter box out. This is only because the old rubber bushings can become dry and fall to pieces, but the z06 doesn't have these bushing. It is hard mounted into place. I just swapped stock shifter with the MGW shifter. I haven't had any problems, no noise or excessive vibration. The shifter is really firm for a few hundred miles, but will loosen up. The shifts from front to back are a little shorter than stock, but the movement from side to side is crazy short. Im not sure about the other brands, but MGW's stuff is top notch!
Old Feb 24, 2013 | 08:07 AM
wmjosjr's Avatar
wmjosjr
Thank You TGz06.
Old Feb 24, 2013 | 07:07 PM
TGz06's Avatar
TGz06
Thank You TGz6.
Anytime!
Old Feb 24, 2013 | 07:28 PM
Dave concrete's Avatar
Dave concrete
I did the MGW but did not change the box. I love the shifter very percise.
Old Feb 25, 2013 | 10:31 AM
mittens's Avatar
mittens
Had a MGW in my C6, and now in my C5Z, also had a Hurst in a C5Z before this one.
MGW all the way
Old Feb 26, 2013 | 10:12 PM
Vette Buddy's Avatar
Vette Buddy
My friend has no complaints with his B&M. Because its a Z06, the shifter box is already solid mounted so all ya do is bolt in the shifter. Took maybe a half hour to install.
Old Feb 27, 2013 | 08:47 AM
MGW George's Avatar
0MGW George
Former Vendor
St. Jude Donor '08-'11
you are mistaken about the shifter box. we do not even have our box out yet. the box you have is a GM unit. the shifter is an MGW but we have not released our billet box yet.
regards
george
Old Feb 27, 2013 | 05:33 PM
z06scentair
regards
george
Stand corrected shifter box was purchased from TPS.
George,
When do you plan to release the billet box and what adavntages do you expect?
Old Feb 27, 2013 | 06:07 PM
skyavonee's Avatar
skyavonee
George,
Old Feb 28, 2013 | 07:17 PM
Ak_Darin's Avatar
Ak_Darin
I replaced the stock Z06 shifter with an MGW and new GM shifter box. The difference is night and day.
As others have said, the MGW is TIGHT out of the box but loosens up nicely over a short period of time. It's a first class, well engineered piece of machinery and the installation instructions/video are as good as anything I've gotten from any manufacturer anywhere.
I don't think I'd even try anything else at this point.
To Shifters
Old Mar 1, 2013 | 08:23 AM
V2lude's Avatar
V2lude
I have the LG Motorsports shifter and I love it. All short shifters are essentially the same design. LG was the best deal hands down.
Old Mar 1, 2013 | 09:04 AM
81c3's Avatar
81c3
Ive tried Kirban, B&M and stock. Then I tried MGW. I have had the MGW for a couple of years now and its the best so far. Do the shifter alignment procedure and the anti venom mod and it will be perfect.
Old Mar 1, 2013 | 10:53 AM
VenomInside's Avatar
VenomInside
MGW. Had it on a bunch of my cobra's and now my Z. LOVE LOVE LOVE IT!
