C5 corvette wide fenders only pics!!
#1441
Bump
#1442
😏 Back in the day we'd call that kinda governmental attitude the little communistic... Do it the government way or off with your head... you Brit hot roder!
sbadd99 (02-24-2024)
#1443
Aussie not British, I've never been called a Pommy before (LOL)
#1444
Hi everyone!
What kind of offset and backspacing is everyone running?
I have 2 inch rear flares (TPE-Style) and 1 inch front flares coming from CorvetteCreations.
I want to start figuring out my wheel situation. I think I need to run 19 inch rims minimum because of the C7Z brakes.
I’m sad CCW doesn’t make the SP550 anymore. Lol
#1445
Hi everyone!
#1446
I just bought a c5 and purchased a bunch of stuff for it and one of those parts was a set of these rear panels Although before i paint and install i will be making and glassing in some vents like on the c6 GS.
I also ordered carbon fiber ground effects like i see on some of the pics posted in here along with all new blacked out lights and just had the windows tinted last weekend.
vette is a 98 manual with 45k miles on it in silver
#1447
Hi everyone!
I have backed myself into a need front wide body fenders rather than want…. I went down the rabbit hole of adding CCBs from a C6 ZR1 and to clear the front caliper I ended up with an aggressive offset that in the end still wasn’t enough so a 1/2 spacer had to be added. Now I have a cartoonish amount of front poke and have to either scrap the brake mods or add fronts which obviously means I have to do the rear as well
im still on the fence as what to do. Can you or anyone else that has non fabricated/altered front flares post up some good pics
TIA
#1448
If you have a buddy with a C7 Z06 or Grand Sport, do you think you can throw a front wheel on his to see if it'll clear? I was told 19s are necessary for the front. I was just talking to CCW yesterday and they don't make the SP series anymore. I'm definitely interested in yours if they'll fit.
#1449
TIA
TIA
#1450
You should take a look at C7 Z06 or C7 Grand Sport iron brakes. You need to get C7 knuckles as well so they will fit, but they should stop a C5 wonderfully. Our cars are like 500+ lbs lighter than the C7 Z06. 14 inch front rotors and 13.4 inch rear rotors instead of the 15.5 inch fronts/15 inch rears on the C6 ZR1 CCBs.
If I was going to bail from this I’d either put the stock brakes back on or go to a C6 Z06 setup
maybe I’ll just buy a C6 Z07/ZR1 and have spares on hand
if I had a run of the mill Z06 I wouldn’t blink an eye to tear it apart with aftermarket body panels but my car is a very low mile example and I’m not sure it’s the car to do that to
hoping to see some decent pics of wide fronts
#1451
I wish I was still in Texas so I could test fit the fronts on these brakes.
#1452
#1453
This is a great flared fender thread! I have done lots of mod's to my car over the years but I regret this is one mod I never got to....It is definitely one of the more pricier ones when you consider the cost of the flare panels, the needed customized body work for them come out really good, and the cost of any possible wheel changes.
#1454
Received 1,871 Likes
OH THREE Z (04-08-2024)
#1455
FYRARMS (04-06-2024)
#1456
I'm going the poorboy wide tire route. Don't really want to mess with widebody rear fenders again so I'm seriously considering the idea of going with a 19x11 rear wheel with +65 offset. If my measurements are correct, I should be able to fit a 325/30/19 tire under the car, without poke.
#1457
That's not a bad fit as it is, Dan.
FYRARMS (04-07-2024)
#1458
TIA
TIA
#1459
The problem is the backspacing of your wheels, not the offset. You shouldn't need any more clearance for those wheels than for C6 Z06 brakes. Both have larger calipers than most aftermarket BBKs. I was able to fit 19x10s on the front with 275s without any poke. I did end up having a problem in the back with poke for 19x11, though. I ended up needing a 1" flare in the back for that.
FYRARMS (04-10-2024)
#1460
Maxx_Z06 (04-15-2024)
