Check engine light
Old Mar 7, 2013 | 10:17 PM
Tim04C5's Avatar
Tim04C5
Default Check engine light
I've had this come on before but it always clears by itself. The times it happened were mostly after putting in fuel. This time no fuel was added. It's been a few days now. All these codes were history, PCM P0171 + P0174, IPC B0516, and HVAC B0367. Does anyone have an idea what these are? Or any way I can clear them? Thanks..
Old Mar 7, 2013 | 10:23 PM
calvins's Avatar
calvins
Oldtimer
http://www.digitalcorvettes.com/foru...d.php?p=512062
Old Mar 7, 2013 | 11:38 PM
Tim04C5's Avatar
Tim04C5
Originally Posted by 8VETTE7
The P0171 and P0174 are bank 1 and bank 2 lean on the O2 sensors. Likely causes are an air leak after the MAF. Check for cracked hoses and or loose clamps in the air intake system after the MAF.. It could also be caused by a gas cap that has a bad seal.
Roger that, I'll check those. Thank you both for your help!
Old Mar 8, 2013 | 07:51 AM
3sACROWD's Avatar
3sACROWD
My vote is the gas cap needs to be replaced.
Old Mar 8, 2013 | 09:14 AM
Tim04C5's Avatar
Tim04C5
I checked the air hoses for leaks/cracks and the gas cap seal, which appeared ok. I spun the cap in a few turns, and this morning, no more light! Thanks for the assist guys!!
Old Mar 8, 2013 | 03:44 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
I've had very similar issues in the past. If you suspect the gas cap, take the O ring off it, clean it and put it back on.
rr
Old Mar 8, 2013 | 04:40 PM
PvtJoker21's Avatar
PvtJoker21
if you do not put the gas cap on all the way, or incorrectly or the threads dont match, it will throw a code at you. This is a big NO NO when you have to get a smog check!
Old Mar 8, 2013 | 06:18 PM
Tim04C5's Avatar
Tim04C5
Codes are cleared, check, o-ring is clean, check. No more check engine light, check... thanks again to my corvette brothers
Old Mar 16, 2013 | 11:34 AM
leetownreb's Avatar
leetownreb
How do you clear the codes??
Old Mar 16, 2013 | 11:44 AM
dadaroo's Avatar
dadaroo
I have an o-ring fuel cap on 2 of my cars. I like to put a little silicone lubricant on them so they seat well and don't stick when the cap is removed. Just a thing I do being an **** engineer.
Old Mar 16, 2013 | 11:55 AM
calvins's Avatar
calvins
Oldtimer
www.youtube.com/watch?v=SviRjIsy9G4
Old Mar 16, 2013 | 01:18 PM
leetownreb's Avatar
leetownreb
Originally Posted by calvins
Thanx. Was very informative. BTW, how long have you been in Potown??
To Check engine light
