Coolant leak
Old Mar 11, 2013 | 07:13 PM
scott1094's Avatar
scott1094
Default Coolant leak
It was warm yesterday so I fired up the Vette after the long winter sleep. Fired right up and ran just fine. A little later I noticed a small puddle under the left (drivers) side. Popped the hood and the source was near the outlet hose but the hose was dry. I'm assuming the well known radiator tank leak. So, is this a simple R & R of the radiator and hoses or are there some surprises in store? Thanks for any advice.
Scott
Old Mar 11, 2013 | 08:30 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Depending on how many miles you have the plastic end tanks may be starting to get hair line cracks. If this is the case its time to replace!
