[Z06] Valve Spring Replacement
Old Mar 11, 2013 | 10:34 PM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
Default Valve Spring Replacement
I'd like to replace my valve springs before I get the car on the track for some track days. Should I go with OEM springs or would it benefit me to pick up a kit like one of these: http://forums.corvetteforum.com/c5-g...-kit-sale.html
Car is an '03 z06, 58k miles, 6 speed. I'd like to eventually be at 400-450rwhp, but that's far down the line. Thoughts?
Old Mar 11, 2013 | 11:29 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Definitely go with a dual spring!
Old Mar 12, 2013 | 12:14 AM
dangerz's Avatar
dangerz
Wouldn't that require me to upgrade the rockers to support them?
Old Mar 12, 2013 | 12:22 AM
janky's Avatar
janky
I'm totally not an expert on this subject, but I just spent a good deal of time with an engine tuner wrenching on my car this weekend and when I said I was thinking about getting the PAC 1518 springs for exactly the same reason as you, he didn't hesitate to say they were an excellent choice for my motor. I've been researching this for awhile and haven't found a negative comment yet.
Old Mar 12, 2013 | 12:40 AM
PeteZ06's Avatar
PeteZ06
I've gone with dual springs on my last 4 cars and never had to replace rockers.
Old Mar 12, 2013 | 09:44 AM
MY03C5Z's Avatar
MY03C5Z
If your goal is to reach 450 rwhp you will be doing a cam to get there. Ive read that its best to install new valve springs whenever you do a cam. I replaced my original springs with the new style LS2/3 blue springs last summer for piece of mind. Not sure if I'll do a bigger cam down the road, for now I think the new stock springs are fine. I would install dual springs if I ever decide to change cams. Just my $.02.
Old Mar 12, 2013 | 10:06 AM
Dave_2003_TRZ06's Avatar
Dave_2003_TRZ06
if the cam is under .600 lift, a good single like the pac1518 is fine...if you are installing a cam over .600 lift I would use a dual spring...stock rockers just fine, however I would consider the comp cam trunion upgrade to them...
Old Mar 12, 2013 | 01:17 PM
Driver220's Avatar
Driver220
I used 1218s...i dont plan on doing heads or a cam anytime soon, just basic bolt ons.
To Valve Spring Replacement
