Small Power Mods
Old Mar 12, 2013 | 10:58 AM
JaxEagle's Avatar
JaxEagle
Default Small Power Mods
What small power mods, those in the 5hp-30hp range, do you think are commonly left out? Just curious to figure out if I am leaving any stones unturned. I am not going to do a S/C before 2014, if at all, however I may do a few other small mods if I can find a few so that they add up to enough to make it worth the tune.
Old Mar 12, 2013 | 11:37 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
None of these are usually left out since the small mods tend not to break the bank. If you're going blower, Headers will be a good place to get torque and power as well as efficiency.
Old Mar 12, 2013 | 12:08 PM
Many people do LT headers and an new air intake as relatively inexpensive power adding mods.
Old Mar 12, 2013 | 12:19 PM
sobregonso's Avatar
sobregonso
ported throttle body
Old Mar 12, 2013 | 01:16 PM
JaxEagle's Avatar
JaxEagle
My question may not have been clear. I have all typical stuff, H/C, LT, etc. I am asking what items are sometimes forgotten in a typical build?
Old Mar 12, 2013 | 01:17 PM
JaxEagle's Avatar
JaxEagle
Good one. Got it though.
Old Mar 12, 2013 | 01:18 PM
JaxEagle's Avatar
JaxEagle
As I replied to RadioFlyer, I don't think I made the question clear. Sorry!
Old Mar 12, 2013 | 01:24 PM
Iwant1c5z's Avatar
Iwant1c5z
Under drive pulley?
Old Mar 12, 2013 | 02:12 PM
TheRadioFlyer
Supporting Vendor
Originally Posted by Iwant1c5z
Under drive pulley?
probably not good for the blower
Old Mar 12, 2013 | 02:23 PM
Bluesteve1's Avatar
Bluesteve1
how much does a ported TB add and is it worth it on a C5 that will just have an intake and headers?
Old Mar 12, 2013 | 02:59 PM
LoneStarLizzard's Avatar
LoneStarLizzard
Paint your car Millenium Yellow. MY cares are faster than the rest; ergo the yellow paint adds the additional power you are looking for.
The Lizzard
Old Mar 12, 2013 | 04:49 PM
GenerationX1's Avatar
GenerationX1
Don't know if it adds much but the throttle body bypass mod is a cheap mod if you haven't already done it.
Old Mar 12, 2013 | 05:04 PM
WKMCD's Avatar
WKMCD
A good tune by a good tuner.. Yes you can run a CAI. ported TB, LS6 intake and LT's without it you're leaving HP on the table.
Old Mar 12, 2013 | 09:34 PM
James2002z06's Avatar
James2002z06
Default Hmmm.
Injectors , coil packs ( MSD only ) good H pipe ...
Old Mar 12, 2013 | 10:23 PM
frenchsquared's Avatar
frenchsquared
proper tune up, cleaning your air filter often enough, proper oil, proper tire pressure are all often neglected. I am new to the LS's so I don't know a lot of tricks on these engines.
Yes some oils can increase hp and gas millage.
Royal Purple (to my disbelief) has increase my wife's Toyota 2 miles per gallon.
Old Mar 12, 2013 | 10:47 PM
JaxEagle's Avatar
JaxEagle
And perhaps not good given that I have a significant audio setup? What does an under drive pulley cost though, just out of curiosity?
Old Mar 12, 2013 | 10:52 PM
yaknow's Avatar
yaknow
there are no cheap mods to give you any increase power. If your looking for hp down the road, expecet to spend $10-$20 per horse if you do the mods yourself. If you are depending on a mechanic the cost will be significantly more.
First you need to determine is your goal. Then start with the basics headers, cat back exhaust, CAI and go from there. Don't waste your money and time on by re-doing or re purchasing parts you have already replaced. You will need to to a fair amount of research before you start. Spend some time on the tech side and read, read , read. My goal was 500 hp at the crank. What got me there headers vararam, exhaust, cat back, cam, heads, intake, injectors, theromastate, and numerous other parts all working together with a good tune.
Good Luck
To Small Power Mods
Old Mar 12, 2013 | 10:57 PM
JaxEagle's Avatar
JaxEagle
Thanks to all for the replies. Perhaps I have been, yet again, unclear. I already have all of the typical mods. I am at 450rwhp with my NA setup. Just curious what stones I may be leaving unturned without going to a blower.
Old Mar 12, 2013 | 11:48 PM
Must_Have_Z's Avatar
Must_Have_Z
Define "typical stuff." You mentioned H/C. Does that include a better intake manifold? Bigger throttle body? Upgraded fuel injectors? You needed to include your build details so we can help you out.
Old Mar 13, 2013 | 12:03 AM
frenchsquared
some reason I was thinking small price... my bad.
