Automatic weight distribution
Old Mar 16, 2013 | 06:09 AM
NotAnExpert's Avatar
NotAnExpert
St. Jude Donor '13
Default Automatic weight distribution
I searched and found i could find the front and rear weight of my 02 a4 on the sticker on the door. After checking them and dividing them by the total weight of the car my distribution is 48/52.
My confusion comes from the manual has a distribution of 49/51 and the t-56 sits in the rear. How can they move the trans further to the front near the engine and only change the ratio by 1%?
Have they added weight to the rear to compensate?
Old Mar 16, 2013 | 06:50 AM
Silverback51's Avatar
Silverback51
What are you trying to achieve by doing this?
Old Mar 16, 2013 | 09:23 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Boy am I
All this for 1%
Old Mar 16, 2013 | 09:28 AM
calvins's Avatar
calvins
Oldtimer
Why in the world would I care about 1%?
Old Mar 16, 2013 | 10:30 AM
AU N EGL's Avatar
AU N EGL
Unless your W2W racing or Autocross, it does not matter.
Hint Move the battery to the right rear compartment. LPE has the battery extension cables.
Old Mar 16, 2013 | 10:38 AM
scott1094's Avatar
scott1094
Torque converter in the rear, auto weighs more plus much more fluid weight. Clutch and heavy flywheel in front and transmission weighs less. Should equal a higher rear weight bias for the automatic.
Scott
Old Mar 16, 2013 | 02:56 PM
NotAnExpert
St. Jude Donor '13
What I was trying to ask, in the early morning after just getting off work, was how does gm allow for both the manual with the trans in the rear, and the auto with the trans towards the front to have relatively equal weight distributions?
I think scott1094 tried to answer this but its a little broken up. So the trans weight less...than what? Clutch and heavy flywheel in front where the trans and engine are....wouldnt that creat more weight up front?
My assumption here is that the front would be significantly heavier and the weight ratio would be nothing close to 50/50. I am just wondering what GM engineered in orser to balance it out with having the auto trans up from like camero and trans ams.
Old Mar 16, 2013 | 03:06 PM
The auto tranny is in the rear of the car - same as the manual tranny.
Old Mar 16, 2013 | 05:32 PM
WetteVette's Avatar
WetteVette
I, too, was wondering if the OP knew the C5 has a transaxle setup.
Old Mar 16, 2013 | 05:39 PM
NotAnExpert
St. Jude Donor '13
Ok now I am really confused. I do take solice in atleast I chose an appropriate forum name. I looked under the car last night and it looked like the transmission was at the front of the car. However I'm thinking the steel cover I saw was not the transmission but the oil pan cover.I am not familiar with a trans axle system and was not aware of that was the name the system was given. So now it looks like I have enough info to do some research. Thanks for your replies.
Old Mar 16, 2013 | 05:43 PM
WKMCD's Avatar
WKMCD
Torque converter in the rear?????
Old Mar 16, 2013 | 09:35 PM
andynpz's Avatar
andynpz
Yes, torque converter in the rear is right.
And being super-picky it is not a transaxle (which is transmission and differential all in one casing). it is just a rear mounted transmission.
Answer to OP's question is as scott1094 wrote, auto tranny and torque converter weigh more than manual tranny - which has clutch at front.
Old Mar 16, 2013 | 09:54 PM
Originally Posted by andynpz
.And being super-picky it is not a transaxle (which is transmission and differential all in one casing). it is just a rear mounted transmission..
However, GM has called it a transaxle ever since the introduction of the C5.
Old Mar 17, 2013 | 09:40 AM
andynpz's Avatar
andynpz
True enough
How are we doing, NotanExpert? Does the different weight distribution for auto and manual make some sense now?
Old Mar 17, 2013 | 02:23 PM
NotAnExpert
St. Jude Donor '13
True enough
Yeah im good on that. It was after work in the early morning. I looked under the car and in my haze I thought the oil pan was the bottom of the trans which is why I call myself NotAnExpert. This way when I ask stupid questions its already expected.
Old Mar 17, 2013 | 10:45 PM
PhysicsDude55's Avatar
PhysicsDude55
Correct me if I'm wrong but the weights listed on the door is the GROSS vehicle weight, not the curb weight. Right? Gross weight is the rating for the suspension basically, its something like 300lbs more than the car actually weighs, and would allow for the variation that you've noticed.
Old Mar 18, 2013 | 08:13 AM
scott1094's Avatar
scott1094
I'll try again.
Makes no difference if you have an automatic or manual, the transmission is in the rear. They both bolt directly to the rear axle. In the manual the heavy clutch and flywheel are bolted to the engine (more weight to the front) the torque converter (automatic) is in the rear (more weight to the rear). A six speed manual weighs less than the four speed automatic. So, the front to rear weight bias is greater for the automatic than the six speed manual. Not by a lot but enough that GM lists both to be on the safe side (for the lawyers I suppose).
Scott
Old Mar 18, 2013 | 09:05 AM
oldschoolvette's Avatar
oldschoolvette
Originally Posted by scott1094
I'll try again.
Scott
I dont like lawyers
To Automatic weight distribution
