LMC5 collumn lock bypass Installation
Old Mar 16, 2013 | 10:41 AM
bj1k's Avatar
bj1k
Default LMC5 collumn lock bypass Installation
Since the weather is still bad I decided to install the LMC5 module today . Not clear on one thing. The paperwork says disconnect the battery. Is there any danger of losing settings or locking up the radio ? Would it help to plug in a cigarette adapter with a 9 volt battery or is it even necessary ?
Old Mar 16, 2013 | 10:51 AM
black match box's Avatar
black match box
plug in the 9 volt. unless you know the radio code.
Old Mar 16, 2013 | 11:51 AM
dadaroo's Avatar
dadaroo
Here is a Forum Thread that discusses how to address the radio security issue in case you need it. Have not used it.
http://forums.corvetteforum.com/c5-t...lock-code.html
Old Mar 16, 2013 | 02:55 PM
First off, do you have a red blinking light on the radio when you turn off the car? If so, then the TheftLock is activated. Hopefully you have the four digit code if it is activated. If the light is not blinking, you won't have to worry about it - you will just have to reset the stations unless you hook up the 9 V battery.
Old Mar 16, 2013 | 04:12 PM
bj1k's Avatar
bj1k
Thanks Jack. I didn't know these radios had a red security light so it must not be activated. Never saw one.
To LMC5 collumn lock bypass Installation
