[Z06] DIY synchro job?
Old Mar 20, 2013 | 06:46 PM
danieloneil01's Avatar
danieloneil01
Default DIY synchro job?
I'm in the process of removing the transmission in a 2003 Z for a new clutch for soon to be go fast parts. I know it's most likely not the clutch since the car is stock and has 35k miles. Is it possible to do this with basic hand tools and knowledge?
First gear grinds if I don't put the car into 1st really slow while not moving and if the car is just rolling forward <1mph it always grinds.
Old Mar 20, 2013 | 06:57 PM
sabastian458's Avatar
sabastian458
You will most likely need a press and bearing collars and separators.
Old Mar 20, 2013 | 07:09 PM
danieloneil01
So it doable for an idiot to do or just easier to take to a shop to do?
Old Mar 20, 2013 | 07:29 PM
MY03C5Z's Avatar
MY03C5Z
I've replaced many clutches myself in my 97 z28, I would not attempt to dissasemble the trans myself though if it needs new syncros. I consider myself pretty mechanically inclined but rear and trans rebuilds are something that require some specialized skills and tools. Take it to a shop imo.
Old Mar 20, 2013 | 07:34 PM
ctusser's Avatar
ctusser
While your in there it would be wise to upgrade to billet synchro keys and a steel 3-4 fork.
Old Mar 20, 2013 | 08:07 PM
danieloneil01
ctusser do you know a vendor that sells those parts? I'll take it somewhere to get installed.
Old Mar 20, 2013 | 09:02 PM
ctusser's Avatar
ctusser
thegearbox.org
Old Mar 20, 2013 | 09:50 PM
danieloneil01
I don't see the M12 on there.
Old Mar 20, 2013 | 11:21 PM
ctusser's Avatar
ctusser
It's just a variation of the T56
Bronze pads are a good idea as well.
Old Mar 21, 2013 | 09:26 AM
PEETYZ's Avatar
PEETYZ
Thegearbox.org is best place.
I will be doing mine soon as well. Couple new syncros, steal 3-4 fork, billet keys, broze fork pads ( basically same things as a stage 2 rebuild) Yours being a 2003 may already have a steel 3-4 fork however.
This may help you get the trans down and out:
Clutch Install http://forums.corvetteforum.com/c5-t...all-guide.html
http://www.cajundude.com/c5techhome.htm
Sorry to Hijack but this may be useful for us both: Any other useful hints guys? I have access to a 2 post and 4 post lift. Which is easier?
To DIY synchro job?
