How much would reported damage affect your offer?
The car:
Manual trans Z51, white/cashmere, old roof, HUD, Bose & disc changer (both broken), 102k miles, non-vette dealer asking $20k.
Reported damage on CARFAX:
Passenger side hit a guardrail, 5 years ago. North Carolina reports minor to moderate damage vaguely as from "bent fender" to "broken equipment". My take is that "you could probably drive away, but you wouldn't want to." No frame damage or airbag deployment reported to Carfax (which I guess means neither was paid by an insurance company--unclear to me). Car was repaired and sold the next year.
Even though it's listed Z51, it does not have cross drilled brake rotors. (Not sure if they came that way in 2004.) The hood didn't close for me on the passenger side when I dropped it like normal--salesman got it to go by push it as it's going down. The latch by the battery looked fine, might be a fine alignment thing. (Driver's headlight looked slight off to me, photo below.) I have not seen the underside of the car on a lift yet, only what my cell phone shots can show.
I'd get the frame checked before buying. I'd also have my insurance company run the VIN.
Question is: what else would be essential? And how much would you lower your offer? $1-2k?
To my novice eyes, they repaired it well:
There are several other minor issues with the car, in case anyone knows or has seen this before (More important to less important)
- Exhaust not aligned--CORSA stainless (unsure what model) on passenger side are a lot higher (see photos)
- no sound from front "Bose" speakers only the tinny rears
- Sticky radio buttons, ewww
- CD changer cartridge in trunk didn't eject when I opened the cover
- Bent antenna (radio stations seemed clear enough though, & it went down fine)
- top is dingy, maybe original
- visible wires/harness under drivers seat. (power seat works)
- HUD brightness slider **** missing
- Plastic thing next to ignition is marred (see photo below)
- Plastic near driver's seatbelt "seems kind of gappy", not clear if it's put together correctly
- Hand brake needs tightening
- Significant tire noise with top up (no divider), they're Kumho, I think Ecsta SPT
- Dislike: dark tinted windows (sides, rear, band across top), side panel molding, bent/dented intake accordian, aftermarket "professional" battery, brake calipers seem dirty (red)
It is too much, plus it sounds like a lot of problems that you have already called out.
The C5's did not come with drilled rotors. It also has C6 style wheels.
For that much money, you should be able to find a really nice one.
Good luck.
Keep shopping, there are lots of wonderful C5 Corvettes out there without all those issues.
You'll find it, just be patient.
http://forums.corvetteforum.com/c5-c...-22-000-a.html
offer them 12K...when they say no the tell them see ya!!
keep looking
It drove pretty good. I doubt they'll take $11k. We'll see.
By the way, interesting point: this is a case where KBB gets it really wrong, I guess! (They say $23k retail!)
