quick question
Old Mar 23, 2013 | 11:12 AM
momo20's Avatar
momo20
Default quick question
I am getting ready to install my c6z shocks and was wondering if I should lower my c5z while I am in each wheel well area ..or should I wait till after the car has settled from the shocks then lower it? Thanks
Old Mar 23, 2013 | 12:12 PM
DDaaryl's Avatar
DDaaryl
no, don't lower it
Old Mar 23, 2013 | 12:20 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I think if you plan on lowering it do it now because you will have good access to do so, The best starting point is to turn the same number of threads on each corner, I lowered mine all the way on stock bolts and like it, Any lower would be an issue for me.
Mr.Bill
Old Mar 23, 2013 | 12:21 PM
Bent98c5's Avatar
Bent98c5
If I went back to do it again I wouldn't lower mine again. The po of my car put aftermarket bolts on tho. If they were stock i bet it wouldnt be anywhere near as bad. Just make sure u keep some shock travel. As soon as my new bolts are in mines going back up
Old Mar 23, 2013 | 01:02 PM
momo20's Avatar
momo20
Mr.Bill
ok that is great to know! and it seems to be mixed views on lowering it...hmmm
Old Mar 23, 2013 | 01:07 PM
Mr.Bill's Avatar
Mr.Bill
There is a driving curve to learn when lowered, But they look and handle so much better in my opinion.
Mr.Bill
Old Mar 23, 2013 | 01:09 PM
momo20's Avatar
momo20
Mr.Bill
I have read speed bumps and dips are a bit more of a challenge..lol
Old Mar 23, 2013 | 01:10 PM
Mr.Bill's Avatar
Mr.Bill
That is true, But not a big challenge, That is where the learning curve comes into place.
Old Mar 23, 2013 | 01:15 PM
jcsperson's Avatar
jcsperson
NC Events Coordinator
My C5 coupe rides about .3-.4" higher with the C6Z shocks than it did on the stockers. They've been on six months and haven't settled noticeably. Others have mentioned that they've experienced the same thing. If you like where your wheels are in your wheel wells, you might want to lower the car a bit to compensate.
Old Mar 23, 2013 | 04:34 PM
Mr. Jean's Avatar
Mr. Jean
Also on driveways, huh Bill?
Old Mar 23, 2013 | 04:51 PM
Mr.Bill's Avatar
Mr.Bill
I forgot that....lol
Old Mar 23, 2013 | 04:59 PM
James2002z06's Avatar
James2002z06
Mine is lowered on after market bolts , I don't seem to have any problems if anything it handles better than it did before
Now once it was lowered I did take it back to have the rear raised back up a 1/2 inch
Old Mar 23, 2013 | 05:17 PM
Mr.Bill's Avatar
Mr.Bill
That is one BAD **** Z you have there.....
Old Mar 23, 2013 | 05:21 PM
racebum's Avatar
racebum
use scales or at a minimum measure frame points when you lower the car. typically you setup any car about 1/16th higher on the drivers side to split the difference on driver weight
also make sure you get the car realigned after changing ride height
Old Mar 23, 2013 | 05:30 PM
James2002z06
Default Coming from an old law deifying guy ...
Like yourself , ill take that as a compliment ....lol
Old Mar 23, 2013 | 07:35 PM
momo20's Avatar
momo20
well the deed is done..installed the c6 Z06 shocks...used the zip tie method for installing the fronts. worked like a charm..the rear however I ended up using a ratchet strap which allow for easy removal and install of the rear shock.rear took me 15 mins a side...I did not lower at this time as I want to see if the car will settle any more if at all, then I will proceed to lower it..thanks for all the lightening quick response's I love this fourm!
To quick question
