Z06
Old Mar 23, 2013 | 06:35 PM
n38139's Avatar
n38139
8th Gear
Default Z06
I just purchased a used 2003 Z06, new to Corvette but have several cars I have built / maintain. I have a question.
I noticed that other vettes I looked at (Not z cars) had run flat tires but I know mine doesn't and is not suppose to. My question other than performance, why does the z not have run flat tires? I like the car for it's looks etc and not it's power or speed nor do I intend to run it hard or on a track. I just like it. I have another set of wheels and wondered if I could buy a set of run flats and keep my others for resale or performance?
thanks
Steve
Old Mar 23, 2013 | 06:54 PM
racebum's Avatar
racebum
weight and performance. the OE z06 tires were very light for their sizes. runflats are typically quite a bit heavier and in the worst possible place..the tire
the z06 came with an inflation kit made to service small puncture wounds
Old Mar 23, 2013 | 07:02 PM
calvins's Avatar
calvins
Oldtimer
Congratulations and welcome. Most other owners ditch the runplats and get real rubber.
OH BTW: Pictures are considered mandatory...
Old Mar 23, 2013 | 07:03 PM
n38139's Avatar
n38139
8th Gear
Default OK, but---
But except for the weight, which doesn't have a factor for how I am going to drive it and operate it, is there any reason I can't? I don't like the idea of going anywhere with the possibility that I can be stuck on the side of the road, waiting on a roll back or worse to come get me.
Old Mar 23, 2013 | 07:06 PM
calvins's Avatar
calvins
Oldtimer
I don't see why you couldn't run them if you chose to. I'd rather wait for roadside assistance. The other option is carry fix-a-flat and a small 12V compressor, and/or a tire patch kit.
Paul 75 L82's Avatar
Paul 75 L82
You need to check the date on the tires. They can still look good but be to old to be safe. New tires on a Z06 is a great feel. Enjoy the Z.
Old Mar 23, 2013 | 07:25 PM
n38139's Avatar
n38139
8th Gear
It doesn't have the original tires on it now. They are Michelin tires, much quieter than other vettes I test drove. I love the car, just don't like not having a spare especially if I am on the highway or away from home.
Old Mar 23, 2013 | 07:31 PM
The non-runflat tires performed better in terms of handling than the runflats and the weight savings were an added benefit.
Old Mar 23, 2013 | 07:39 PM
calvins's Avatar
calvins
Oldtimer
Yeah, but I *think* he wants to know if there is a reason that he can't run the runflats. I know of none other than the handling and ride, but whatever floats your boat.
Old Mar 24, 2013 | 06:51 AM
Tuscany's Avatar
Tuscany
Runflats are said to require TPMS--else you might be driving on "flats" for a long time without knowing it--which the Z06 also doesn't have. I've heard rumors that Z's might have TPMS support in the computer, though, if the wheels were equipped with sensors. Can anyone else confirm this?
Old Mar 24, 2013 | 07:05 AM
calvins's Avatar
calvins
Oldtimer
Yes you can. Here's a thread on it.
http://www.z06vette.com/forums/f5/tp...estion-123815/
Old Mar 24, 2013 | 07:35 AM
3sACROWD's Avatar
3sACROWD
Put sensors in your wheels and activate the TPMS in the computer. Best investment you'll make.
Since dealerships don't know how to activate the feature in the computer, save yourself some time and print the information in the link below. Save yourself some money by taking print out to a competant mechanic and not a dealership.
While you're at it, add automatic headlights. It is described in the link below as well. You'll spend around $250 total.
Here is a link to the procedure.
http://api.viglink.com/api/click?for...13418432474531
Old Mar 24, 2013 | 08:00 AM
JoeJ's Avatar
JoeJ
3sACROWD, I can't get the link to work, do you have another source?
Old Mar 24, 2013 | 08:14 AM
3sACROWD's Avatar
3sACROWD
Not sure why the link isn't working. I went to my old post under Retrofitting TPMS on a Z06 in the Z06 section of this forum and the link worked. Go to advanced search. Enter TPMS as the search word, enter 3sACROWD under username, select Z06 in the C5 forums.
I tried the cut and paste of the link again and it didn't work. Maybe it is my computer.
Old Mar 24, 2013 | 02:04 PM
JETninja's Avatar
JETninja
WA Events Coordinator
Its not just handling and weight, Run Flats ride HARSH. You will notice the difference. I've done 12K since getting my Z in August of 2011...most of it on SoCal Freeways, never a flat. Keep your eyes open for debris and you'll be fine. And get a AAA card.
In the C5 Z06 Forum there is a C5 Z06 Faq at the top of the page, lots of TPMS info in there...
Old Mar 24, 2013 | 05:27 PM
PHIL MEMPHIS's Avatar
PHIL MEMPHIS
Z06's did not come with run flat tires. They had a wider wheel and supercar tires from the factory. I wouldn't put them on there if it were mine.
Old Mar 26, 2013 | 12:32 PM
vintagez's Avatar
vintagez
Owning a 2003 Z06 this allows me to use the regular non run flat tires but the tpms system will let me know if they are losing air and prevent me getting a flat and ruining my rim, great idea, thanks for the info. At least there is a warning that we can stop and address the issue if a problem is happening, and the weight of the sensors is not that much. Many thanks.
To Z06
Old Mar 26, 2013 | 04:12 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Sure you can. The FRC, which became the Z06, had run flats. Mine has run flats on it. But when it's time to change them I doubt I stay with run flats. Noisy and they don't ride very good.
Old Mar 26, 2013 | 04:25 PM
Phanni's Avatar
Phanni
If you can find run flats to fit on a Z06 rim there is no reason why they won't work. You can also get someone to retune the TPMS system back into the Z06. FWIW, flat tires are rare with today's technology, however, a plug kit and inflator works well for both run flats and regular tires....Most of us have cell phones and something like AAA too.
Old Mar 26, 2013 | 04:32 PM
Zr-1Mike00's Avatar
Zr-1Mike00
Plus in my opinion the runflats had a lot rougher ride. The sidewalls are much stiffer and there is greater road noise compared to traditional tires.
