Repainting bumpers. Remove them?
Old Mar 25, 2013 | 10:07 PM
gleds's Avatar
gleds
Default Repainting bumpers. Remove them?
I am having my bumpers and side skirts touched up/sprayed. Should they be removed or can they be left on? The shop I am looking at using said they use a razor to get a sharp edge prior to painting and if I ask them to remove the bumpers I am sure they will. It will just cost a little more which I am fine with.
Thanks in advance
Old Mar 25, 2013 | 10:17 PM
f6john's Avatar
f6john
I took my nose off when I had it painted.I think it's worth the extra trouble. But I did the r&r, too cheap to pay someone else.
Old Mar 25, 2013 | 10:18 PM
momo20's Avatar
momo20
Thanks in advance
I would say remove them to avoid tape lines they parts once they are taken off can be detailed more then if they are on the car...
Old Mar 26, 2013 | 06:06 AM
oldschoolvette's Avatar
oldschoolvette
Old Mar 26, 2013 | 08:15 AM
4 KRUSIN's Avatar
4 KRUSIN
I had the rear of mine keyed last summer. The body shop where I took it highly recommended that it be removed. I'm glad I went that way.
Old Mar 26, 2013 | 10:25 AM
1BADAZ50TH's Avatar
1BADAZ50TH
Remove them. No edges that can peel later. if your going to do it, do it right.
Old Mar 26, 2013 | 11:16 AM
3boystoys's Avatar
3boystoys
Remove them. Should be easier for them to paint too off the car.
Old Mar 26, 2013 | 11:19 AM
Chicago1's Avatar
Chicago1
stock side skirts? They are not coming off more like chipped off.
Old Mar 26, 2013 | 09:18 PM
AntonioZ06's Avatar
AntonioZ06
yeah, I was gonna say the same thing. Remove the bumper. But the skirts are going to have to stay on. Tell them that before hand and just ask them to take care in how they tape everything both visible, and underneath where they wrap the frame
Old Mar 26, 2013 | 10:25 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Old Mar 27, 2013 | 12:55 AM
momo20's Avatar
momo20
good advise!
Old Jun 15, 2013 | 11:50 AM
ster1ing's Avatar
ster1ing
Cruising
Do you have a link to instructions on removing a front bumper?
Old Jun 15, 2013 | 11:55 AM
ster1ing's Avatar
ster1ing
Cruising
Just found it...
http://forums.corvetteforum.com/1572211126-post8.html
Old Jun 15, 2013 | 02:34 PM
Virtual Geezer's Avatar
Virtual Geezer
gleds: I see from your profile that your Vette is silver. Ask them (strongly) if they will guarantee a bumper-cover-to-body match without blending. Silver is one of the worst colors for matching. They could loosen the covers a bit to get the wraparound spray technique others here have suggested and then blend into the body paint. Just don't want you to be disappointed.
My 2004 coupe is machine silver and under certain lighting conditions my rear bumper cover with orig. factory paint looks like crap (mismatch). I've visited two reputable shops over the years to see if I can get better results. Neither wanted to touch it.
If anyone reading this knows of a body shop in the Twin Cities (MN) that could help me, let me know!
Old Jun 15, 2013 | 02:55 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I don't want to hijack the discussion, but to those who have had the job done, did you strip the bumpers first, and if yes, how did you do it?
Old Jun 15, 2013 | 04:09 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would say remove them as long as you have a good painter and he doesn't have to do any blending.
Old Jun 15, 2013 | 04:55 PM
Phanni's Avatar
Phanni
The bumpers can be removed in about a half hour. With that said, your decision should be easy.
To Repainting bumpers. Remove them?
Old Jun 15, 2013 | 08:43 PM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
Take them off.
Old Jun 15, 2013 | 09:39 PM
I would take them off to be painted. They are not that difficult to remove and I think you'll get a much better job done.
Old Jun 15, 2013 | 09:44 PM
El original's Avatar
El original
I had my front nose painted while on the car and challenge anyone to see/tell the difference....
