Check Engine Light and Codes
Old Apr 1, 2013 | 10:14 PM
JaxEagle's Avatar
JaxEagle
Default Check Engine Light and Codes
I noticed my check engine light came on so I took her back to the hangar immediately and ran the codes. I had 8 codes, 6 of which had the H for history and were simple/indignificant codes like battery disconnect, etc.
I had 2 codes under the Powertrain computer (P0171 and P0174). This is for Fuel Trim System Lean (Bank 1 and Bank 2). The curious thing is that the code has H and C after it. Does the H and C necessarily mean that it is no longer a relevant code? What does the C indicate? Do these two codes likely account for my Check Engine light being on? I haven't cleared any codes yet. I may take the car to my tuner this week and have him evaluate.
Any comments would be appreciated.
Jax
Old Apr 1, 2013 | 10:36 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Jax
The "C" stands for an issue that is current and still a prob. If you are lean the CEL will come on for sure, You can try to disconnect your battery for a few and see if it will reset anything.
Old Apr 1, 2013 | 10:39 PM
JaxEagle's Avatar
JaxEagle
That makes sense in this case. I don't think any of my other codes had the "C"
Old Apr 1, 2013 | 10:41 PM
JaxEagle's Avatar
JaxEagle
Although it is a bit ambiguous how you can have both a H (historical) and a C (current) at the same time.
Old Apr 1, 2013 | 11:40 PM
JaxEagle's Avatar
JaxEagle
Thanks MB. I will get that lean condition looked at. Before I reset codes or reset battery, I want to address the too lean condition not just make the CEL go away.
I did just have the care tuned about 100 miles ago or so but not sure why the lean condition would show up after 100 miles and not immediately after tuning?
Old Apr 1, 2013 | 11:49 PM
Mr.Bill's Avatar
Mr.Bill
Another thing to check is the air intake and make sure there isn't any air leaks, I believe too much air will give you a lean condition.
Old Apr 2, 2013 | 09:57 AM
JaxEagle's Avatar
JaxEagle
That is logical. Thanks again!
Old Apr 2, 2013 | 10:22 AM
Alvin@PCMofNC's Avatar
Alvin@PCMofNC
Supporting Vendor
It can take a while to set the codes, especially if it's right on the threshold of being lean enough to set that code. Is the car modified? I'd take it back to the tuner and have him go back over it.
If you recently installed a cold air intake, you may want to clean the MAF as well, sometimes the filters are too heavily oiled and will get onto the MAF elements, skewing the readings.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Mail Order Tuning & Sales
704-307-4227
Old Apr 2, 2013 | 11:28 AM
JaxEagle's Avatar
JaxEagle
Good info, thank you. That is exactly what I am going to do.
Originally Posted by 8VETTE7
As has been stated an air leak before the MAF is the most likely cause of the two C codes you have. Also as stated an overly oiled CAI may have deposited excess oil on the MAF screen.
Also a possible cause is leaks in the hoses for the PCV system. Over time the PCV hoses crack and otherwise deteriorate from engine heat and oil.
All 3 should be checked carefully.
I will suggest my tuner check all of those possibilities. I appreciate the reply!
Old Apr 2, 2013 | 12:05 PM
dadaroo's Avatar
dadaroo
Understand that H (historical) means it has happened in the past. C (current)means it is happening now. If they both show then it did happen and is still happening. If you shut the car down and check codes, some codes will only show H and not C. I am not sure which ones but it is always a good idea if you are having an issue to check the codes while the car is still running.
PS: If anyone can clarify or provide additional info please feel free to chime in, I will certainly not be offended.
To Check Engine Light and Codes
