Noise when cold
Old Apr 4, 2013 | 01:32 PM
Racerx9's Avatar
Racerx9
5th Gear
Default Noise when cold
OK so I have a 2000 C5 convertible with 40,000 miles, I have noticed that when I pull it out of garage and leave down the street it makes kind of a rubbing noise like a metal rub every revolution so not constant. If the car just warms up to operating temp. the noise still remains when I leave, always under load never when idleing or reving motor. Now when I get it on the road and put my foot into it the noise goes away and does not come back until the next morning. Weird, anybody got ideas what to look for?
Old Apr 4, 2013 | 03:17 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
First thing I would look at is the brakes if it only does it while moving.
Old Apr 4, 2013 | 07:26 PM
Racerx9's Avatar
Racerx9
5th Gear
only when I first start rolling and not brakes, or anything in wheel area. Goes away when I open it up and then does not come back until next day
Old Apr 4, 2013 | 07:34 PM
Mr.Bill's Avatar
Mr.Bill
Brakes have a natural drag on the rotors and sometimes can cause a sound when going slow and are cold, You can try a few high speed stops and see if that helps.
Old Apr 4, 2013 | 10:45 PM
bj1k's Avatar
bj1k
Does it sound like it is coming from the drive shaft ( torque tube ) area ?
Old Apr 4, 2013 | 10:49 PM
TorchRedRocket's Avatar
TorchRedRocket
Could your parking brake be somewhat stuck and dragging?
Old Apr 4, 2013 | 11:34 PM
Racerx9's Avatar
Racerx9
5th Gear
It does sound like from torque tube area.
Old Apr 5, 2013 | 09:58 AM
bj1k's Avatar
bj1k
Not good , but at least you know where to start. Unusual at those miles but it depends how hard it was driven.
Old Apr 5, 2013 | 10:29 AM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Rear differential? If it's a grinding, chattering noise, it's normal. It that's it change out your diff fluid, (I suggest Amsoil) with limited slip additive.
Old Apr 5, 2013 | 01:15 PM
Racerx9's Avatar
Racerx9
5th Gear
I will check the diff. fluid, 40000 miles probably should be changed. Don't think that is it but worth a shot. Hard to tell when the noise goes away after accelerating and doesn't come back till next day. Need to find Dyno to put it on and run it so I can pin point better
Old Apr 6, 2013 | 09:24 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Doesn't sound like it is diff chatter which would occur when doing sharp turns - yours sounds like it occurs going straight. Unfortunately, could be a lot of things including torque tube, wheel bearings, brake rotor/pad rub as mentioned above. I'd check the torque on your rear axle nuts as a starter. If it goes away, I'd guess most likely cause is brake rotor/pad rub which is only an annoyance but nothing physically wrong. You know what kind of pads you have? Good luck!
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Noise when cold
