[Z06] knock from rear
Old Apr 8, 2013 | 09:39 AM
ls6vettenc's Avatar
ls6vettenc
Default knock from rear
I recently installed a borla stinger exhaust on my 03 z. Immediately after install, I began having a knocking noise over bumps. I have checked and rechecked several times, and the exhaust is not hitting anything. They only other thing that was messed with was the rear sway bar, which is tight. It almost sounds like something is hitting the plastic underbody of the car. Im stumped and frustrated. I did have to jack the car up really high on the right side to removed the stock exhaust, which put alot of weight on the left rear, which is where the noise seems to be coming from, did I possibly hurt something? Any help is appreciated.
Old Apr 8, 2013 | 05:42 PM
ls6vettenc's Avatar
ls6vettenc
bump......i dont want to pay the dealer to look at it
Old Apr 8, 2013 | 06:17 PM
sami85L98's Avatar
sami85L98
No you did not cause any damage by jacking too high on one side, i did that waay too many times mine and friends with absolutely no problem.
check muffler rubber clamp by rear bumper side, you may not insert muffler hooks properly or not inserted into rubber properly......i did that one time was frustrated and jack up the car...start chasing noise by hitting exhaust all the way upto muffler hangers...yepper i found it.
Old Apr 8, 2013 | 06:23 PM
ls6vettenc's Avatar
ls6vettenc
thanks for the reply. I didnt think I hurt it by jacking it up like that, but you never know. Ive checked those rubber hooks, they do seem a bit looser than with the factory mufflers, but not overly loose as to cause a noise, but I will check that again, right now.
Old Apr 8, 2013 | 07:02 PM
ls6vettenc's Avatar
ls6vettenc
Well, rechecked the rubber mounts, they seem fine. shook the exhaust hard, cant get it to duplicate the sound. The sway bar links are tight, but the links themselves seem pretty free, I can easily move them back and forth with two fingers. Is that normal?
Old Apr 9, 2013 | 12:51 AM
alextz's Avatar
alextz
check the axle nuts, 33mm I believe. I think out of 10 C5 Z06s I have checked, at least 6 of them I could get a quarter inch turn with a torque wrench set to 120 ftlbs
Old Apr 9, 2013 | 09:17 AM
BrentC5Z's Avatar
BrentC5Z
Also check the hanger springs at the rear of the H or X pipe (whichever you have) They can come unhooked pretty easy when the mufflers are removed.
Old Apr 9, 2013 | 08:35 PM
ls6vettenc's Avatar
ls6vettenc
havnt checked this yet, but from what people describe this causing is not really what im having. it only does it over bumps.
Old Apr 9, 2013 | 08:36 PM
ls6vettenc's Avatar
ls6vettenc
Checked these last night when I was under the car, they seem to be on tight.
Old Apr 10, 2013 | 08:28 PM
ls6vettenc's Avatar
ls6vettenc
bump
Old Apr 11, 2013 | 11:47 AM
alextz's Avatar
alextz
i had clunk over bumps too, and it was the axle nut.
check sway bar endlinks, they might be bad, although seem tight on casual inspection.
Old Apr 11, 2013 | 09:19 PM
ls6vettenc's Avatar
ls6vettenc
thanks, I will check these again. im thinking about ditching the sway bar and driving to see if it is coming from that.
To knock from rear
