2001 z06 low voltage???
Old Apr 8, 2013 | 04:20 PM
1badsilversvt's Avatar
1badsilversvt
Default 2001 z06 low voltage???
I recently got my first corvette. A 2001 Z06. Have had it about 3 weeks and just yesterday, when I shut the car off, left it for about three hours, when I got back in to start it, I turned the key over and the gauge lights flashed and it said low voltage and no gauges would work. Well I turned the key off and back on and everything was fine. Now every time I try it, the first couple times turning the key over, lights flash and says low voltage-check system charge, then you turn key over again, all gauges light up and the car starts fine, but still says low voltage, I checked battery and its good and the volt gauge on the inside when it does start reads 14.1 volts. So has anyone had this issue or anything like it? Any feed back will be appreciated, thank alot
Old Apr 8, 2013 | 04:32 PM
GTJim's Avatar
GTJim
Have you checked to make sure the cables are tight? I'd also put a volt meter on the battery to check the voltage.
Old Apr 8, 2013 | 05:11 PM
1badsilversvt
Cables are tight. Will put volt meter on tonight. Thanks
Old Apr 8, 2013 | 07:36 PM
1badsilversvt
Anyone else? I need your guys help. Thanks
Old Apr 8, 2013 | 10:07 PM
1badsilversvt
Ok, checked everything with a volt meter and the battery seems to be a little low.... So I guess I'll try a new battery tomorrow?
Old Apr 8, 2013 | 10:28 PM
GTJim's Avatar
GTJim
Same thing happened to me. Put a new battery in and problem solved.
Old Apr 8, 2013 | 11:54 PM
1KLRTOY's Avatar
1KLRTOY
It could be a bad ignition switch,I replaced the one in my 01 it solved a lot of problems with low voltage
Old Apr 9, 2013 | 01:27 PM
1badsilversvt
Was it hard pulling old one out and new one in?
Old Apr 9, 2013 | 02:20 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Fix it before relays start to melt.......Weak batteries are not well tolerated in these cars!
Old Apr 9, 2013 | 02:23 PM
racebum's Avatar
racebum
get a battery tender for your new battery. if you go a few days - week without driving you can kill/drain the battery. also would be worth checking to make sure you don't have a strong current drain.
Old Apr 9, 2013 | 08:28 PM
darkstar.c5's Avatar
darkstar.c5
you didnt happen to leave your cell phone car charger plugged in? the accessory plugs are on even with the car off.
Old Apr 9, 2013 | 09:27 PM
1badsilversvt
Can I go ahead and do a column lock bypass before it hits me? Just to be on the safe side?
Old Apr 9, 2013 | 10:14 PM
yaknow's Avatar
yaknow
yes, cheap insurance
Old Apr 10, 2013 | 12:59 PM
tacman's Avatar
tacman
St. Jude Donor '13
Default Ignition Switch
Bill Curlee has assembled an excellent tutorial on ignition switch removal and repair/replacement...
http://forums.corvetteforum.com/show....php?t=1951626
Old Apr 10, 2013 | 01:01 PM
tacman's Avatar
tacman
St. Jude Donor '13
I just tried the link and it dead-ended. Sorry!
Try this...
http://forums.corvetteforum.com/c5-t...ch-repair.html
One last try...
http://forums.corvetteforum.com/c5-t...ine-quits.html
Old Apr 11, 2013 | 04:12 PM
1badsilversvt
Thank you tacman, and thanks to bill. I pulled out ignition and followed all the steps and cleaned everything and haven't had a issue yet. I think that was the culprit. Installing the LMC5 tomorrow. Thanks guys
Old Jul 4, 2013 | 03:29 PM
Frankg01z's Avatar
Frankg01z
1st Gear
Lol Ur story sounds exactly like mine. I asked many mechanics n they all wanted $$$ to check it out n couldnt find anything. I was bout 2 head 2 da dealer, but I saw dis post. Did changing da battery work 4 u n solved da problem?
To 2001 z06 low voltage???
