Frc
That's how I look at it. I bought mine for $17K. At the time Z06's were going from $23 if you stole it to $25 for a clean driver. For the $7K I saved I've done heads, cam, headers, mufflers, intake, CAI, shocks, shifter, clutch, torque tube, etc and have bought two sets of tires and I'm still where I would be cost wise if I'd have bought a Z06. And, I've got a very streetable 415 WHP and 490 CHP.
Just my .02.
Kurt
The car may be a bit 'stiffer' due to the body, but it's got nohing to do with the frame (chassis).
The FRC is simply stiffer than all because it eliminates the removable roof panel (coupe), and actually adds a roof (vs vert), then drops all the weight from the removal of the rear glass.
Just my .02.
Kurt
Just my .02.
Kurt
I think GM internally referred to them as the Billy Bob or something like that.
The FRCs before 2001 came with Z51 suspension and manual trans. After 2001, the weight was reduced, an LS6 replace the LS1, which meant higher HP and torque, bigger swaybars, beefed up suspension, different wheel camber, stiffer shocks with F41 suspension (Z06 only).
BTW, no lightweight carbon hood on Z06's until '04, which was WAY out of my budget. Thinner glass windshield, yea, I'll give you that.
As far as my time, wrenching is my hobbie. I have a job, wife, two kids, a mortgage, 3 sailboats, a kayak and a Corvette. I don't have a lot of free time, but when I do, wrenching is my choice. Hell, I don't even watch TV anymore.
To each his own, but for the same $24K I had a lot of FUN wrenching and have the car I want for my needs. If you just want to get in it and drive it, then get the Z06....GM's done everything for you already.
Kurt
Really?
You knew my intent when I said, " The C-5 chassis is identical for all models. There is no 'extra' bracing for any of the models. "
damn.
