Pipe Cutter :
Old Apr 13, 2013 | 01:46 PM
hockeyspokes's Avatar
hockeyspokes
Default Pipe Cutter :
Does anyone have a used chain cutter for tail pipes they want to let go cheap . I only have two cuts to make and then will likely never use again .
Old Apr 13, 2013 | 04:25 PM
hockeyspokes
Default thanks
Originally Posted by 8VETTE7
Auto Zone and many other parts stores have a "Free loan a tool" program. You put down a deposit on the tool, take the tool, use it and as long as you return the tool (unbroken) you get all your deposit back.
I used this solution for the chain cutter you mention when I installed an X-Pipe on my car. Easy way to gain access to a tool that would otherwise become a "one use tool".
I'll check my local area .
Old Apr 14, 2013 | 03:20 AM
Cliff8928's Avatar
Cliff8928
That chain cutter is great as long as it's sharp! They will still take it back broken, BTW.
Old Apr 14, 2013 | 06:20 AM
tentuna's Avatar
tentuna
If that doesn't work, try Harbor Freight, if the tool is for occasional use, as a hobbyist their tools are fine.
Old Apr 14, 2013 | 06:40 AM
oldschoolvette's Avatar
oldschoolvette
most small exhaust shops would cut it for you for a nominal fee
that way no tool to buy, try and resell, frustration level is lower as well?
just an idea
Old Jul 22, 2013 | 07:57 PM
Noma01's Avatar
Noma01
Hockey I'm trying to reply to your pm but your box is full
To Pipe Cutter :
