Missing DIC codes?
Old Apr 25, 2013 | 11:13 AM
machfive98's Avatar
machfive98
Default Missing DIC codes?
What are the odds of a 2003 vert having NO DIC codes?
Can these be found once someone has reset them?
Old Apr 25, 2013 | 11:18 AM
3boystoys's Avatar
3boystoys
I check my 01 often and generally have no codes.
Old Apr 25, 2013 | 11:55 AM
dadaroo's Avatar
dadaroo
If you are really concerned, we can help you create some, but don't recommend it.
Once the codes are removed they are gone. If there is an issue you would need to start it/drive it and then pull the codes to see if something is going on.
Be happy, don't worry as the song says. Your day (codes) will come like everyone else.
Old Apr 25, 2013 | 12:10 PM
machfive98's Avatar
machfive98
I'm asking because I'm looking at buying a vette from a dealer, and this is the first time I've seen a 10 year old vette with no codes showing.
Old Apr 25, 2013 | 12:19 PM
B747VET's Avatar
B747VET
If you make a hearty and aggressive 20 min test drive, getting all temps up to max, there is a fair chance that any recently erased but unrepaired codes will magically reappear.
Barring that, GM can pull up their portion of any repairs made to that Vette.
FWIW, my car also had zero codes when delivered in 2011 with 19K miles.
Otherwise, old erased codes are gone forever. But, don't worry, sooner or later they will all come back to say "Welcome!"
Old Apr 25, 2013 | 01:18 PM
AngryTurtle's Avatar
AngryTurtle
Get a handheld scanner and check if the readiness tests are complete. If so all is well. If not it has recently been reset and I wouldnt buy it until they are complete.
Old Apr 25, 2013 | 01:31 PM
3boystoys's Avatar
3boystoys
No codes an all I/M's pass is a very good sign.
Old Apr 25, 2013 | 02:28 PM
Originally Posted by 8VETTE7
As the others have stated take it for a lengthy test ride and pull codes BEFORE you shut off the ignition and then AGAIN after you shut off the engine. Anything that needs repairing will most likely show its head.....
And good luck with finding the right car for you.
To Missing DIC codes?
