Has anyone installed LED tail lights and have an EMI issue. When I apply the brakes or signal, I get interference on my radio with stations with weak signals. Strong station or CD playing is not affected. What's the best way to shield the EMI?
I couldn't tell you what it was called, but I have read another thread about this issue, and I believe they had as least a workable solution to it. I've never had any EMI issues with mine.
running the wires through a ferrite core maybe?
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Tks,
I have a friend that bought a set of the white led tail lights off eBay, You know the cheap ones and they did the same thing, We tried grounding them different and nothing that we did worked, He ended up getting rid of them for a set from JWMotoring and the issue went away.
