Battery Replacement.. recommendations?
Old May 7, 2013 | 09:23 PM
v03z06's Avatar
v03z06
Default Battery Replacement.. recommendations?
As the title states, who is using what out there to replace their battery? I was leaning towards an Optima red top but I hear just as much bad as good...thoughts???
Old May 7, 2013 | 10:22 PM
PhysicsDude55's Avatar
PhysicsDude55
I don't think Optima red tops are ideal for C5s, since our electronics have a slow drain on the battery over time, which the Optimas don't like.
If you keep a battery tender on the car all the time, its pretty much a non-issue, but for the money, I think if you're looking for a premium battery, the Sears Platinum battery is a better fit for a C5 than an Optima.
Old May 7, 2013 | 10:28 PM
racebum's Avatar
racebum
diehard and kirkland batteries are made by the same place.
if you're just getting a regular group 75 replacement check costco. they are quite a bit less than sears
Old May 7, 2013 | 10:31 PM
PhysicsDude55
The Sears Platinum battery is basically an Oddessy battery from my understanding, its a class above the regular diehard batteries (and about double the price), but it has nearly twice the reserve capacity, and is supposed to be really well made and long lasting.
Just depends on how much money you want to spend.
Old May 7, 2013 | 10:34 PM
I had an Optima Red Top in mine when I bought the car - the battery died right past the 3 year mark. Replaced it with a Sears DieHard Platinum 2 1/2 years ago and no problems so far.
Old May 7, 2013 | 10:40 PM
GrandSportRob's Avatar
GrandSportRob
I put a DieHard Gold in my old C5, great battery, never any issues & only drove it on weekends..
Old May 7, 2013 | 10:42 PM
bartsky's Avatar
bartsky
Oddessy here
Old May 7, 2013 | 11:20 PM
jornahow's Avatar
jornahow
Deka Intimidator AGM battery. I chose this over an Optima. I would have also considered an Odyssey or Sears Platinum.
Old May 8, 2013 | 08:39 AM
Rexrode's Avatar
Rexrode
Default Bosch
I bought a Bosch battery recently from Pep Boys. There are some who recommend 700 and over for cold cranking amps, and 120 and over for reserve capacity. Mine is rated at 90 for reserve capacity, which is starting to worry me. I called Pep Boys yesterday and I was told that Bosch was in the battery group recommended for my car.
Guess I'll wait and see...it seemed to turn over slightly slower yesterday, which is what got me concerned.
Old May 8, 2013 | 12:51 PM
Loc's Avatar
Loc
I have an 8 year old optima red top. If I don't drive the car for a couple weeks it will be dead. I charge it and go.
Old May 8, 2013 | 01:04 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
OK, I have been a red top used for years, I had one in my Corvette and I had one in my 72 Camaro, Never an issue with the one in the Camaro, But the Vette the last couple of months I was having issues, I ended up buying a Interstate Mega Tron Plus with a battery mat and the car starts so mush better now, No codes. So far I am happy with it, I do keep an eye on it, Last thing I want is a leaking battery.
Mr.Bill
Old May 8, 2013 | 01:15 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
C5 needs lots of reserve capacity!!! Get the largest capacity battery you can find. Don't try to save a few dollars on this purchase, for a C5. I've had great luck with the Platinum Die Hard batts. Others are fine too; just think 'huge and powerful'.
Old May 8, 2013 | 05:03 PM
rprinty's Avatar
rprinty
Duralast Platinum here. No issues so far (about six months).
Old May 8, 2013 | 05:06 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
My original OEM battery lasted 7 years in Florida heat with nothing but a trickle charger when necessary. After 7 years, I decided not to further test my luck and I replaced it with another AC Delco 7-year professional battery.
For me it was an easy decision as I went with the "If it's not broken, don't fix it route".
Old May 8, 2013 | 06:01 PM
thisMSGgood4me's Avatar
thisMSGgood4me
But your original OEM battery wasn't broken, so it looks to me like you didn't follow your own advice, because you fixed something that wasn't broken yet.
Old May 8, 2013 | 06:17 PM
Rexde1's Avatar
Rexde1
I bought a Duralast because it was Sunday and that was about 2 1/2 years ago. Its been good but my car doesnt sit for long periods
Old May 8, 2013 | 06:22 PM
racebum's Avatar
racebum
what's the big difference between these and optimas? i know the standard autozone/diehard/kirkland/exide are all the same johnson battery
the platinum looks like the special one but i have never researched on why
To Battery Replacement.. recommendations?
Old May 8, 2013 | 06:59 PM
crazystevex's Avatar
crazystevex
Yes I would recommend you replace your bad battery
Old May 8, 2013 | 07:22 PM
MSG C5's Avatar
MSG C5
There's a comedian in every crowd!
Old May 9, 2013 | 11:06 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Red Top here. The last one I had was six yrs plus old & was still o.k. but I thought I was pushing it. I use a CETK 3300 trickle charger all the time (garage queen). I've read the Red Tops don't like to charged after going dead. Suggest using a battery mat whichever battery you get.
