Need help diagnosing a problem - videos
Old May 11, 2013 | 03:41 PM
SFL_driver's Avatar
SFL_driver
Default Need help diagnosing a problem - videos
I need help diagnosing this problem.
As you can see my RR wheel has side to side play ( no top to bottom play). Originally I thought it was the hub/bearing assembly but that was replaced only a year ago.
In the second video you can see the tie rod moving slightly. Could the problem be the tie rod ball joint? And if the tie rod is moving I would assume the whole knuckle is moving and therefore the problem should not be the hub, right?
Old May 11, 2013 | 03:43 PM
bladex10's Avatar
bladex10
Wheel bearing?
Old May 11, 2013 | 04:00 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I didn't see anything moving behind the rotor, That leads me to believe wheel bearings, How is the other side?
http://www.corvettemods.com/product....FS9dQgodCVcA-Q
Old May 11, 2013 | 04:10 PM
SFL_driver's Avatar
SFL_driver
The other side is fine. Last year I hit a curb on the RR and bent the tie rod. I had the tie rod and RR hub replaced and upgraded all four rims to ZR1 replicas.
This is part of the reason I think it might have something to do with the lower tie rod end / ball joint looking connection.
Old May 11, 2013 | 04:14 PM
Mr.Bill's Avatar
Mr.Bill
You know, I enlarged the video and it does like there is some movement in the ball joint.
Old May 11, 2013 | 04:29 PM
SFL_driver's Avatar
SFL_driver
That's what I thought too. Of course, it was easier to see in person.
I'm going to have to search how to replace that.
I like the new avatar by the way.
Old May 11, 2013 | 04:35 PM
rprinty's Avatar
rprinty
Default Outer Tie Rod End
Looks like the outer tie rod end to me. I just replace mine at 70,000 miles and they were both shot. I had the same type of side to side play when the wheel was gripped at 9 and 3 o'clock.
Bob
Old May 11, 2013 | 05:00 PM
SFL_driver's Avatar
SFL_driver
Bob
I believe you're right.
Old May 11, 2013 | 05:03 PM
Mr.Bill's Avatar
Mr.Bill
Bob
I agree., That is what I meant, But I called it a ball joint.
Old May 11, 2013 | 07:00 PM
3sACROWD's Avatar
3sACROWD
Grab the tie rod and try to move it. It shouldn't have any play in it. It looks like yours does.
Old May 11, 2013 | 07:35 PM
sircampsalot2's Avatar
sircampsalot2
Bad Tie rod end, You have waaay too much play in it. replace them and you will be good
Old May 11, 2013 | 07:38 PM
SFL_driver's Avatar
SFL_driver
Thanks everyone.
How serious of a problem is this. Aka am I okay to drive on it for a week or two?
I'm either going to go with VBP tie rod ends or a bump steer kit.
To Need help diagnosing a problem - videos
