LED Under Hood light Mod.
Old Mar 31, 2014 | 07:57 PM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
Originally Posted by OKZ06
For the price this was a amazing mod, quite a night and day difference big thanks to the for sale section for the amazing deal.
Had trouble with the before pictures but here is a after.
I just did this upgrade to my under hood light, except I used the 18 LED pad. Nice and bright under there now.
Old Mar 31, 2014 | 08:05 PM
DonsLS1's Avatar
DonsLS1
Okay, so who is it that sells a good kit?
Old Mar 31, 2014 | 08:13 PM
Navybluevette
I picked up the 18 LED dome light pad from everyones favorite auction site.
http://www.ebay.com/itm/180791518587...84.m1497.l2649
Soldered spades on the wires, built up the back of the pad with double sided tape, spades slid over the stock male connectors in the housing (red (hot) wire is the bottom connector and reattached the lens.
Old Mar 31, 2014 | 08:27 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Frank:
You know the rules.... Pics or it did not happen.....
I'll check it out next weekend
Toque
Old Mar 31, 2014 | 08:29 PM
GenerationX1's Avatar
GenerationX1
Yeap... exactly what I did. Looks great!!
Here is a pic of mine.
Old Mar 31, 2014 | 09:03 PM
olbear1962's Avatar
olbear1962
Did this a while back. A great mod indeed!
Old Mar 31, 2014 | 09:56 PM
Navybluevette
Originally Posted by Toque
Frank:
Toque
OK Mark you got me, here ya go, remember I'm no Vann taking pictures.
The LEDs actually very bright when the hood is first opened, this picture was taken after a several minutes of the hood being open
Old Mar 31, 2014 | 10:12 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
We are expecting a Cree LED version of this in the next couple of weeks.
Old Mar 31, 2014 | 10:24 PM
old stingray's Avatar
old stingray
This looks BRIGHT. Where did you get yours?
Old Mar 31, 2014 | 11:04 PM
GenerationX1
I purchased it off of fleabay. It is a panel LED that has 16 little led's on it. I actually purchased a five pack of them.
Old Mar 31, 2014 | 11:31 PM
chasboy's Avatar
chasboy
Oldtimer
I hope this is not too stupid a question, but how do we figure out which LED to buy? How do we figure output, input voltage, need resistor or not?
Old Apr 1, 2014 | 12:13 AM
GenerationX1
Not a stupid question at all. Here is a link that I followed per Mark aka toquez06 from the forums on here. His site has been a great deal of help for me and others.
Click link:
http://www.toquez06.com/led.html
Old Apr 1, 2014 | 07:42 AM
  #33
rwlc5's Avatar
rwlc5
Does the entire LED light fit within the space of the original lens so that the lens cover can be reinstalled over top of it?
The auction site has these 16 bulb panels that also come with 3 different types of adaptors. Can the adapter that is round on both ends be used to insert into the clips where the existing bulb inserts?
Old Apr 1, 2014 | 08:56 AM
  #34
Navybluevette
Yes the 16 and for that fact 18 bulb panels fit in the space and the cover fits right over the panel.
Throw the adaptors away and just connect spades the the red and black wires off of the panel, spades will slide over the existing connector pieces in the housing, you may need to squeeze them a little. The red wire should connect to the bottom connector in the housing. You probably could use the adaptor but there would be quite a bit of extra wire in the housing making it hard to get then panel in.
Check out Marks link as mentioned above.
Old Apr 1, 2014 | 08:59 AM
  #35
rwlc5's Avatar
rwlc5
Thanks Navybluevette.
Old Apr 1, 2014 | 07:09 PM
  #36
Navybluevette
Will these be brighter than the SMT Led's?
Old Apr 1, 2014 | 08:38 PM
  #37
Toque's Avatar
Toque
Ain't that the truth ! He takes some COOOOL pics !
Toque
To LED Under Hood light Mod.
Old Apr 1, 2014 | 10:07 PM
  #38
chasboy's Avatar
chasboy
Oldtimer
Rwlc5, I tried that yesterday. The festoon adapter doesn't fit. The stock bulb is an oddball. I'm going to remove the entire housing to play with it.
Old Apr 2, 2014 | 03:59 PM
  #39
chasboy's Avatar
chasboy
Oldtimer
I just tried to restore everything back to original and the original bulb won't light! Voltage at the contacts is 11.38. I tested the bulb with a small 9V battery and a larger drill battery and it seems fine. When I test the contacts with an LED the light is not as bright as directly from the battery. Voltage to the plug that goes into the housing is also 11.38.
This is strange.
Old Apr 2, 2014 | 04:19 PM
  #40
dimler's Avatar
dimler
Default Led
Lower the hood, turn the key on, raise hood and see what happens. On my you have to go thru a cycle and the LEDs on back to bright. There is some kind of voltage reduction cycle. I don't understand it all but mine works this way.
