[Z06] Check engine code from CAI?
Old May 19, 2013 | 07:34 PM
WannaC5Z's Avatar
WannaC5Z
Default Check engine code from CAI?
Anyone else experienced this happening after installing a cold air intake? I have a SLP Blackwing and it has been on for about two months...about 500 miles. Just yesterday it threw a check engine code so I had it read and removed at O'Reilly's. It was intake air related. It came back on today while driving around. I hate to pay for a tune or programmer just to get this adjusted. I am really tapped out after buying a second set of wheels/tires for the track.
Old May 19, 2013 | 10:06 PM
Hitman227's Avatar
Hitman227
Hmm don't know, did you replace or modify the MAF Sensor after an O'Reilly's intake? This will throw codes.
Old May 19, 2013 | 10:37 PM
WannaC5Z's Avatar
WannaC5Z
Huh? I just had the code read and then removed at O'Reilly's. The car is bone stock other than the Blackwing.
Old May 19, 2013 | 10:51 PM
Hitman227's Avatar
Hitman227
I'm sorry, you have a Blackwing Cold Air Induction, obviously you're not talking about an O'Reilly's CAI.
Anytime you do anything to the MAF Sensor, be prepared to retune to correct problems, that's all.
With the code removed your engine will be fine although I'd check it subsequently because you don't want to be driving around with codes.
Old May 20, 2013 | 09:12 AM
magneto10's Avatar
magneto10
I had a similar experience- halltech stinger added on to my 02 in 2005.
(only engine mod)-
Had one or two lean fuel bank codes thrown until a year or two ago. then I started getting them a lot- before a tune I tried the honeycomb filter (by halltech- have yet to see that code again.
If these are your codes- might want to give it a try
Old May 20, 2013 | 09:18 AM
nullpointer's Avatar
nullpointer
Was it a lean code?
Old May 20, 2013 | 10:23 AM
WannaC5Z's Avatar
WannaC5Z
(only engine mod)-
What is a "honeycomb filter"? Is this something made by Halltech?
Originally Posted by nullpointer
Was it a lean code?
It means you are getting more air than fuel. Rich means you are getting too much fuel and not enough air.
Old May 20, 2013 | 10:35 AM
nullpointer
Yep, I know was it means - I've tuned a few of these cars I was asking if you looked up the description of the code you had.
Old May 20, 2013 | 10:39 AM
WannaC5Z's Avatar
WannaC5Z
LOL...sorry I misread your question. I thought you said "what is a lean code?"
No like an idiot I didn't write it down. It threw it again so I need to go down and have it read again.
Old May 20, 2013 | 10:47 AM
nullpointer
haha thought so, you can also read the codes using the DIC so you don't have to go to the store to read them.
Old May 20, 2013 | 12:05 PM
DARRYLZO6's Avatar
DARRYLZO6
Check to make sure you have all the clamps tight with no gaps. Please pay special attention to clamp around the silicone coupling next to the throttle body. sometimes you have to feel around the bottom by hand to make sure the clamp lines up around the silicone coupling. Also make sure that you have a screen on your MAF.
Old May 20, 2013 | 12:24 PM
tacman's Avatar
tacman
St. Jude Donor '13
Default Reading Codes
Previous posters seem to be right on - air leak or missing MAF screen. Although a remote possibility, inspect your wiring to the MAF to make sure it hasn't been rubbing on the S Belt.
BTW, how to check your own codes...
http://www.c5forum.com/ayc/dtcdic.php
There's a great DIY sticky in the Tech/Performance Forum
Old May 20, 2013 | 02:05 PM
WannaC5Z's Avatar
WannaC5Z
Awesome! These Vettes really are nicely equipped with technology. A few levels above the old Cobra I sold.
Old May 20, 2013 | 05:34 PM
DARRYLZO6's Avatar
DARRYLZO6
If its bone stock, Im assuming that you have the screenless MAF that the 02-04 models have. Since your tapped out, get the Haltech honeycomb screen for about $35. Install the screen, then make sure the clamps are tight and lined up, ESPECIALLY where the silicone hose connects to the throttle body. This should solve your problem without paying $300+ for a tune.
Old May 20, 2013 | 05:36 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Saw one for sale in the C5 parts for sale.
Old May 20, 2013 | 06:43 PM
RedZMonte's Avatar
RedZMonte
+1 for maf screen. i didnt get a lean code on mine with the CAI but I put the halltec honeycomb in to make sure i was getting a good clean accurate reading to the maf for proper maf readings. Alot of memebers here said they got a lean code with a CAI and the screen fixed the problem. its holes are larger then the LS1 mafs and doesnt seem to be a restriction.
skyavonee's Avatar
skyavonee
I've seen MAF screens suggested by dozens of people in various different threads, so I'm not picking on anyone specifically, but...
If the purpose of adding the CAI was to increase power, then why would you turn around and add an obstruction to the air inlet afterward? It doesn't make any sense to me. If you can't afford a dyno tune, I say either get a mail-order tune, or just put your stock intake back on. You can even remove the cover from the stock intake box for added airflow without needing a MAF screen. Just my 2 cents.
To Check engine code from CAI?
Old May 21, 2013 | 01:19 AM
Supercharged111's Avatar
Supercharged111
It's not at all uncommon as it typically increases the turbulence of the air coming into the MAF. You wanted a tune anyway, right? Your 2001 has a vastly different tune than the 02-04, I was shocked when I put the timing maps side by side. 2001 is more aggressive IIRC. Didn't look at fuel, but I'm sure it's different with different cams as well. If you're about to pull the trigger on headers, do it quick so you can get it all tuned in one fell swoop.
Old May 21, 2013 | 02:57 AM
momo20's Avatar
momo20
+1 for the maf screen..i got codes after my vararam intake install...lean left and right banks..installed the maf screen and problem went away!
Old May 21, 2013 | 04:36 PM
WannaC5Z's Avatar
WannaC5Z
Mine is a 2001.
Did you install the Haltech screen others are mentioning?
