I need help finding a screw!
Old May 19, 2013 | 07:49 PM
CNB's Avatar
CNB
Default I need help finding a screw!
I'm changing my corner lights and there is a screw missing. I went to my dealer and they want $5 a piece plus it has to be special ordered. GM calls it a bolt but it looks more like a flange head screw. I tried Lowes and Home Depot with no luck. Keep in mind that I am not looking for the black sheet metal screws that attach the light housing to the bracket. I need the screw that attaches the bracket to the bumper.
Here is a picture of the 10mm screw.
Here is a diagram of the corner light housing and the screw I'm looking for.
Does anyone know the size or where I can get this other then the dealer? Your help is greatly appreciated!
Old May 19, 2013 | 07:51 PM
You might try Marc at VetteNuts - I've called him on some really minor parts and he's come through for me.
Old May 19, 2013 | 08:00 PM
Suthunman's Avatar
Suthunman
St. Jude Donor '14
You should be able to find that at any fastener place. Check to see if there is a Fastenal store in your area.
Old May 19, 2013 | 08:24 PM
momo20's Avatar
momo20
check big r's and some of the mom and pop stores..sometimes they have those odd ball screws
Old May 19, 2013 | 08:55 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
It's called a "high-low" screw, used for threading into thin plastic.
Old May 19, 2013 | 09:38 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Looking at the parts manual, I believe this shows the following spec for that fastener:
Screw, HWH Tapping,M6.6X1.69X20 60 10M BLK ZINC
Might help you when you go to another source.
Old May 20, 2013 | 01:21 AM
tbar1963's Avatar
tbar1963
St. Jude Donor '08
McMaster-Carr.com
Old May 20, 2013 | 07:39 AM
runner140*'s Avatar
runner140*
They are great to work with. Used them on Thursday.
Old May 20, 2013 | 09:00 AM
TXGS507's Avatar
TXGS507
Come on Mike... Just find one that look like it and tap it up in there... It's not like you ever drive the FRC anyway!!
Old May 20, 2013 | 11:04 AM
$$$frumnuttin'
I'm shocked no smartass hasn't told him to visit the local cathouse!
Old May 20, 2013 | 12:11 PM
kabluie's Avatar
kabluie
I've had good luck finding screws and other hardware at the local hardware store. Ace Hardware seems to be better than Home Depot or Lowes for finding small hardware parts. Also they are cheaper than most other places. My previous trips to the big stores like Home Depot have been disappointing at best. I'm to the point where I go to the local hardware store first for any hardware parts. If they don't have it, then I'll try the dealer and just pay the money. You should know that the nearest Home Depot or Lowes is about a hundred miles away so my choices are limited. Back in the day when I lived in Sacramento, I found that what I've just said was true there too.
Good luck
Old May 20, 2013 | 01:31 PM
tentuna's Avatar
tentuna
Believe it or not Sears Hardware is a good source, they seem to carry a lot of the automotive fasteners and and specialty items, much better than Home depot and Loews
Old May 20, 2013 | 02:07 PM
J Vette's Avatar
J Vette
I just hadn't posted yet
Old May 20, 2013 | 02:33 PM
$$$frumnuttin'
...not too late...go for it!
Old May 20, 2013 | 03:56 PM
Rookieracer's Avatar
Rookieracer
That was my first thought when I read the title.
After I got my mind out of the gutter I went and looked in the tool box. I'm pretty sure I have 5 or 10 of those little devils around here somewhere. I ordered them by mistake and figured I would need them sooner or later.
Still looking......
Old May 20, 2013 | 04:09 PM
CNB's Avatar
CNB
Trust me, I've tried everything I have and nothing works. The thread has a heavy pitch and everything I have is fine pitch. I called Mark @ Vettenuts today and he said he would call me back.
Old May 20, 2013 | 04:11 PM
CNB's Avatar
CNB
Thanks for the help guys! Hopefully Vettenuts will pull through.
Old May 20, 2013 | 07:13 PM
Rookieracer
I found the bag I was thinking of and is not the right one for you. Sorry.
To I need help finding a screw!
