Best Shocks ?
Old May 22, 2013 | 09:07 PM
TheBigDog's Avatar
TheBigDog
Default Best Shocks ?
Going to upgrade from stock shocks to either Bilstein or C6Z shocks. I have already upgraded the sway bar and end links. Which is the best for handling and cost? I like a good firm ride and NO sway in corners.
Thanks,
The Big Dog
Old May 22, 2013 | 09:20 PM
jd_black_00's Avatar
jd_black_00
2016 C5 of the Year Finalist
St. Jude Donor '12, '14
I've run both and I prefer the feel of the Bilsteins
Old May 22, 2013 | 09:23 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I looked at both of those type of shocks and eventually purchased a set of Koni FSDs after test riding them in another car. I also upgraded my sways to Z06 sways and added larger wheels/tires.
I love the ride.
Old May 22, 2013 | 10:38 PM
Bent98c5's Avatar
Bent98c5
I have ridden in cars with Konis and I wish I had them.
I have c6z shocks and am very happy with them- but after all my reading I always wonder what if I did bilsteins...
Old May 22, 2013 | 11:34 PM
SilverBullet95's Avatar
SilverBullet95
I've heard many good things about Bilsteins and am planning to get a set myself pretty soon
Old May 23, 2013 | 12:37 AM
Choreo's Avatar
Choreo
I went with the Bilsteins when I upgraded to the C6 Z51 Sways a few years ago. No complaints here.
Old May 23, 2013 | 06:12 AM
Cybermind's Avatar
Cybermind
Bilstein all the way. Best shocks for the money. Actually, I believe that the new C7 will come with Bilstein shocks.
Something else to consider:
OEM = OEM time/mileage limited warranty, not rebuildable, performance will slowly fade
Bilstein = lifetime warranty, rebuildable, guaranteed not to fade
Old May 23, 2013 | 09:15 PM
corvette77's Avatar
corvette77
I put on Bilstein sports last month, and have been very happy with them!
Old May 23, 2013 | 10:29 PM
Tuffguy610's Avatar
Tuffguy610
My car came with Bilsteins already installed from the previous owner and I do not know any different. But the Bilsteins are nice. I may upgrade the sway bars at some point
Old May 25, 2013 | 12:24 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks,
The Big Dog
Your message or what you're looking to do is confusing. Sway bars are more for taking care of sway in the corners. So this probably means your choice of sway bars did not fix your issue. We have plenty of people who have gone up to the C6 Z51 sway bars and have been extremely happy. If you have upgraded to those and still are not satisfied then you should go C6 Z06. Looking for a shock to really control sway in corners is not really best.
And as I normally state, the C6 Z06 shocks coupled with the C6 Z51 sway bars are really the best solution to the base C5 suspension issues for the best price.
Old May 25, 2013 | 12:37 PM
Mattie Num Nums's Avatar
Mattie Num Nums
Have Bilsteins only on the rears (until my Lisle Tool arrives!) and am in love!
Old May 29, 2013 | 10:05 AM
TheBigDog's Avatar
TheBigDog
The shocks are to control float or the soft feeling...I know what sway bars are for!
Old May 29, 2013 | 05:42 PM
NOMOREWORK's Avatar
NOMOREWORK
St. Jude Donor '13-'14-'15
I went with the C6Z06 shocks, no complaints
Old May 29, 2013 | 05:58 PM
CQRT's Avatar
CQRT
At 60k miles, my C5 was still on the factory shocks - - it was okay, but a but "washy" . . .added the Bilsteins and feel a significant difference.
Old Jun 10, 2014 | 10:08 AM
tycksena's Avatar
tycksena
I'm looking to upgrade my rear shocks since I have the rear cradle out doing a clutch swap. I've heard good things about Bilsteins, any suggestions on where to get them?
Old Jun 10, 2014 | 11:39 AM
rwlc5's Avatar
rwlc5
I love the ride.
I have the F45 suspension and even on the touring mode it feelds harsh to me. Do the Koni FSD's give a smoother ride over your typical bumpy roads?
Old Jun 10, 2014 | 06:17 PM
GTJim's Avatar
GTJim
QA1's
To Best Shocks ?
Old Jun 10, 2014 | 06:56 PM
540i 6spd's Avatar
540i 6spd
I've ridden in a bilstien/DRM suspension and it was really nice. Will be my choice when my F55 need to be replaced.
Old Jun 10, 2014 | 09:06 PM
Darrell98's Avatar
Darrell98
I went with the C6 Z06 shocks and the C6 Z51 sway bars and metal ends from GM Parts House. I am very satisfied with the results for the money spent. Really transformed the car. Even the wife noticed the improvement !
Old Jun 11, 2014 | 01:10 AM
GettnBetter's Avatar
GettnBetter
I did Bilstein sports with hotchkis bars and have the Z51 spring rates. The Bilstein sports have been great for me, rather rough ride but very little bounce on concrete freeways. Feels very controllable on or off throttle with usable lift-off oversteer that doesn't end me up in the wrong direction. I have about 60k miles on the setup with no complaints.
The C6Z06 bars were way too grippy in the rear for me, just too fat compared to the fronts. Likely designed to help a less than experienced driver from spinning loops under power on on-ramps cause of it's 500+HP. I could not get the car to turn, was not what I was looking for.
The GM offerings do not come with adjustable links. With stock or fixed length GM links it's impossible to preload the bars correctly and most end up with a magical combination that varies depending on ride height and rim and tire choice. A crapshoot that isn't correct and won't ever have the correct preload.
