Hydrocarbon brake calipers
Old May 27, 2013 | 07:02 PM
Laser Guided's Avatar
Laser Guided
Default Hydrocarbon brake calipers
Has anyone ever had this done? Not sure how it would look and was curious if it could even work/last on that type of part. Probably would look cooler on big brake kits like the c6z as well.
Old May 27, 2013 | 07:07 PM
TriplBlk's Avatar
TriplBlk
I wonder what temperature they can withstand? I know wheels are okay but I'd assume calipers get a lot hotter.
Old May 27, 2013 | 08:26 PM
It would be interesting to know. Perhaps you should contact Pat at American Hydrocarbon and see what he has to say.
Old May 27, 2013 | 08:50 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
The all aluminum big brake calipers do not get hot at all...you can touch them with your finger after a drive....they dissipate heat much faster than cast iron, and keep in mind they are insulated from the hot rotors by the brake pads. So, heat is not a huge issue for the paint...I used standard rattle can paint on mine and there is no heat damage potential.
Old May 27, 2013 | 08:59 PM
robert miller's Avatar
robert miller
Pat should be able to tell him if it will work are not.
Old May 27, 2013 | 09:48 PM
TriplBlk's Avatar
TriplBlk
Thanks for the info
Old May 28, 2013 | 07:44 AM
Mike94ZLT1's Avatar
Mike94ZLT1
You don't think carbon fiber calipers would look a bit odd?
Old May 28, 2013 | 08:08 AM
Crosis's Avatar
Crosis
I dont think we can really say the caliper are insulated by the pads since its the friction caused by the pads that makes the heat and the material in the pads has absolutely no insulating properties.
Old May 28, 2013 | 02:08 PM
Laser Guided
Kinda. I don't think I would pick it over the classic red, but was curious if it has been done/could be done and if there were any pics out there.
To Hydrocarbon brake calipers
