[Z06] 345 tire
Old Jun 2, 2013 | 07:57 AM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Default 345 tire
OK.I. don't have a ZO-6 but I do have the rear brake cooling
set up. I run flares.
I have 325x19 on the rear. Does anyone run 345x19 on the rear
with the rear brake cooling tube still, installed.
Thanks, I need the rear brake cooling for the track.
Old Jun 2, 2013 | 07:58 AM
AU N EGL's Avatar
AU N EGL
345s are big arz tires and take a long time to get heat and grip. U sure U want to do that ?
and they would need 315s up front to balance somewhat or you WILL have too much under steer
Old Jun 2, 2013 | 10:24 AM
miami993c297's Avatar
miami993c297
Missing the 345/30/18 from Michelin ...
Christian
Old Jun 2, 2013 | 11:46 AM
CarBoy's Avatar
CarBoy
It is my understanding that rear ducts are only an issue when doing the mini-tub as the wheel is pushed inwards. Since you have flares I am assuming you got your wheels with a wider lip and not a wider barrel. If that is true it shouldn't be an issue.
You could always take a measurement (while car is full weight on tires/suspension) and see if you have the extra 10mm of clearance....plus some of course....
Old Jun 2, 2013 | 05:57 PM
Dave concrete's Avatar
Dave concrete
I first had 345 30 19 with L5's no issue. Once I installed Coil overs and the car went lower I had to remove them.
Old Jun 2, 2013 | 08:50 PM
road pilot's Avatar
road pilot
I run Hyperco racing springs and I am very low. I guess I will stay
with the 325 and look for a tire with a larger tread. My tire right
now is 11.8 in and I know there are tires over 12.5 in.
Thanks to everyone who responded.
Old Jun 6, 2013 | 09:35 AM
TXGS507's Avatar
TXGS507
I run a 345/19 rear tire w PFADT coilovers, and still retain my cooling ducts... Car sits pretty low.. NO issues whatsoever... It CAN be done.
Old Jun 6, 2013 | 06:50 PM
CarBoy's Avatar
CarBoy
So that's what my car would look like with L5's....?.....
Nice bro
Post more pics
Old Jun 7, 2013 | 06:43 PM
Dave concrete
Most likely because of Alignment and you run Nitto's which are a hair narrow then PS2's. Also do you run a spacer and if yes what size? After the alignment is when it was a bigger issue.
Old Jun 8, 2013 | 10:48 AM
deadcafe's Avatar
deadcafe
Nice bro
Post more pics
Those are TPE flares not Lewis 5's.
Old Jun 8, 2013 | 03:31 PM
TXGS507's Avatar
TXGS507
What he said...
To 345 tire
