[Z06] James
Old Jun 2, 2013 | 05:43 PM
james cox's Avatar
james cox
6th Gear
Default James
Help I have a 2001 z06 it has 124,000 miles came to new orleans to visit parents i live in dallas, drove five blocks from my parents home it was flooding truck drove by causing a lot of water car stalled started it up heard like a clinging noise noticed noise stopped when i reached 45 miles but when i just idled car made same noise engine light does not come on just had oil changed have done all maintance.
any suggestions please help
stranded in New orleans
Old Jun 2, 2013 | 06:30 PM
James2002z06's Avatar
James2002z06
If it were me I would change the oil in it again ASAP ...
Old Jun 2, 2013 | 06:34 PM
james cox's Avatar
james cox
6th Gear
do you think that is the problem or could it be a valve sticking or maybe ac compressor it really sounds like it is in the engine though car responds as if nothing has happened then when it idles hear that sound again
Old Jun 2, 2013 | 06:36 PM
james cox's Avatar
james cox
6th Gear
took car to dealer ship and left it there this morning
Old Jun 2, 2013 | 06:38 PM
James2002z06
That's prolly the best thing you could have done ... Man it could be a number of things
Start with the small things and just keep your fingers crossed brother
Old Jun 2, 2013 | 07:02 PM
james cox's Avatar
james cox
6th Gear
Default james
any other suggestions from any other mechanics
Old Jun 2, 2013 | 07:26 PM
cudamax's Avatar
cudamax
It was Flooding truck drove by causing lots of water??????????? What is that? What do you mean? Water ? lots of water Where? Did you go through water because if the front of the car went through water it could suck water up in through the Intake and man thats the worst thing you can do.
Nothing in this world can compress water. If it gets sucked up into the engine it bends rods
Try to tell us what happened
Old Jun 2, 2013 | 09:20 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
My detailed response is in your other thread.
Oil has NOTHING to do with injested water, or sticking valves. Change the oil 10 times and it won't matter, nor will idling the engine for a day hoping the valves become "unstuck".
You have either a slightly bent rod or hurt rod/crank bearing due to the hydrolocking. To fix it WILL require engine disassembly.
Old Jun 3, 2013 | 01:00 AM
cudamax's Avatar
cudamax
He Hydrolocked it So he did blow thru a large puddle and sucked up water. That Sucks
To James
