outside air temp sensor
Old Jun 10, 2013 | 04:07 PM
larry10's Avatar
larry10
Default outside air temp sensor
Just received a new outside air temp from Corvette Central. I would like for anyone with knowledge of where the sensor is located on the car. My car is a 2000 C5 coupe.
Old Jun 10, 2013 | 04:10 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Facing the front - it is on the lower left hand side of your radiator shroud
Peace
Chip
__________________
..................Click for
Old Jun 10, 2013 | 04:41 PM
MG RED 99's Avatar
MG RED 99
I found the easiest way to get to it was through the headlight. just remove the headlight shroud and reach down and you can unplug the sensor wires and relaese the pushpin that holds the sensor in place. You cansee the tip of the sensor from under the car on the passenger side near the radiator area. See diagram below for a better idea.
[IMG][/IMG]
Old Jun 10, 2013 | 05:05 PM
maxx2200's Avatar
maxx2200
It's on the lower passenger side area. Left if your looking at it from the front, right if you're sitting in the driver's seat.
Old Jun 10, 2013 | 09:14 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
When you go to replace it make sure that the connector is still ok. On mine the connector was corroded and broken so I had to replace the connector along with the new sensor.
Good luck.
Old Jun 11, 2013 | 12:46 AM
With the info and the pics above, you should have no trouble doing the replacement.
Old Jun 11, 2013 | 02:16 PM
larry10's Avatar
larry10
To all the members that responded to my question about the outside temp sensor, I send my thanks. Corvette Forum and its members are the best. It is comforting to know that there are people in the forum who are willing to help Corvette newbies.
To outside air temp sensor
