option code location?
Old Jun 10, 2013 | 07:54 PM
kennedy759's Avatar
kennedy759
Default option code location?
where is the sticker that has all the option codes? my other gm cars had it stuck to the inside of the glove box, but nothing in my 1997.
Old Jun 10, 2013 | 08:07 PM
Corvette_Ed's Avatar
Corvette_Ed
It's inside the glove box. If it's not there it was removed for some reason.
Old Jun 10, 2013 | 08:12 PM
Sonny71's Avatar
Sonny71
Oldtimer
If not in the glove box, you can check on the underside of the 3 rear compartments. I found one attached to the underside of the center compartment on my '01.
Old Jun 10, 2013 | 08:36 PM
kennedy759's Avatar
kennedy759
yep, thanks, it was under the driver side small rear cover. also where can I find a list of what the codes mean? of coarse LS1 and M30 are easy
Old Jun 10, 2013 | 08:51 PM
Chilliwack vettes's Avatar
Chilliwack vettes
Try this http://forums.corvetteforum.com/c5-g...ions-list.html
1997 - http://www.corvetteactioncenter.com/...l#.UbZ0BpyrHTo
b_rad!'s Avatar
b_rad!
http://www.c5registry.com/Production/2K1.htm
To option code location?
