Marred/scratched inside of passenger window
I removed the 'Next generation airbag' sticker and rubbed at the leftover adhesive on the glass with a scotch-brite type of pad, and it left some very light scratches or marring on the glass.
They're VERY light, but nonetheless annoying. Would a glass polishing kit get rid of them or does anyone have any suggestions?
If you can feel them with your fingernail they are permanent. Glass polish can knock down the hard edges and minimize them to a degree.
Next time use a little soapy water and new razor blade.
Glass polishes are for windshields because the glass is softer , but the side and rear glass is tempered and would be too hard to polish out marks. Might minimize them some but not completely. As Calvins said , next time use Goo Gone. One question on this forum could have prevented the problem.
I cannot feel them. They are *extremely* light scratches. I might try the glass polish. Is there any chance at all that this *might* work:
Any glass can be polished. By hand will take longer than using a drill and a really small pad. Also, a light application of a pure wax might hide them. Also might try using paint scratch "remover". Would last a long time since the scratches are on the inside.
You can try using soft toothpaste also. I have used some with a QTip to remove watch crystal scratches with great success.
Received 19,419 Likes
'20-'21-'22-'23-'24
I looked at the kit you referenced. While the polish may be good, I think the pad is way too big for your location. I would go to your local hardware store/Harbour Freight and get a much smaller pad. Does not have to be flat either, could be a rounded end design also. I have used small rounded ones for detail paint polishing is tight areas. With a small pad try using soft toothpaste first. Just make sure you wet the pad with water to help the process. You don't need a high drill speed.
If you end up needing to replace the glass, I have a window that came in replacement door that got mounted a few years ago....The inside of the glass had a 'tint film' applied. I left it on to protect the surface. Its been in my storage just waiting for someone to buy it... Shipping could be tricky, but a good crate will make it possible.
Jennifer
Jennifer
Amazon.com: Glass Polishing Kit (Light Scratches) 2'' 50mm: Home Improvement
