Jacking Puck advice
Old Jun 20, 2013 | 06:21 PM
mikeyrko's Avatar
mikeyrko
Default Jacking Puck advice
I am in need of jacking pucks.
I need some advice on what I should buy, I know I could build my own although looks like it would cost nearly what it would To buy them.
I've seen the type you leave in also some that are all metal.
What do you guys suggest? I don't really need more than 1 maybe 2
Old Jun 20, 2013 | 06:27 PM
CQRT's Avatar
CQRT
Ten bucks - - four hockey pucks and two long eye screws from ACE Hardware - - you're done. Been using then on my C5 and C6 for 8 years - - take them our and store in the rear cubby so you always have them with the car.
Old Jun 20, 2013 | 06:45 PM
DooDooBear1999's Avatar
DooDooBear1999
I spent the extra cash for the aluminum ones. I didn't feel comfortable using pliable rubber that had a greater chance of deformation. Maybe paranoia got the best of me there.
Old Jun 20, 2013 | 07:25 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
In my opinion seeing the Corvette is so low I went and bought the rail savers with built in pucks and I am glad I did.
Mr.Bill
http://www.eliteengineeringusa.com/c...nd-mtg-screws/
Old Jun 20, 2013 | 08:06 PM
Darion's Avatar
Darion
Mr.Bill
plus if the car needs to go on a rack for any reason I don't have to worry about them not using pucks.
Old Jun 20, 2013 | 08:12 PM
ZigZag's Avatar
ZigZag
I got the ones from Corvette Mods and leave them in all the time. Can't see them but they work great.
QCVette's Avatar
QCVette
Active Streak: 90 Days
Mr.Bill
I have just been using hockey pucks, but these look interesting and might provide some protection for the rocker panel all the time instead of just when jacking.
How did they install? Can you jack the car anywhere along the rail saver? Any pictures to show after installed.
Thanks.
Old Jun 20, 2013 | 09:05 PM
mikeyrko's Avatar
mikeyrko
Mr.Bill
Yeah I have seen this before I defiantly plan on getting a set when I have some more $ to spend.
Old Jun 20, 2013 | 09:37 PM
Mr.Bill's Avatar
Mr.Bill
Thanks.
I haven't had to jack up my car with it in 5 years, But I would think you can jack it up anywhere, They have saved my *** a number of times on speed bumps, They hang about maybe a half inch lower than the rockers, You can't see them unless you get down and look under the car. They mounted with 3 or 4 large screws per side.
Old Jun 20, 2013 | 09:45 PM
I use the BMW jacking pucks in mine - cost was about $50 and they snap in place and do not come loose when driving. I would highly recommend them.
Old Jun 20, 2013 | 09:54 PM
Mr.Bill's Avatar
Mr.Bill
I thought about going this way, Buy I thought if you hit a speed bump just right it could shear the puck right off.
Old Jun 20, 2013 | 10:33 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I bought 2 different steel ones on fleabay for $15. each. One goes in the hole for the jack saddle. The other one is flat on the bottom and I use it with my low profile jack.
Old Jun 20, 2013 | 10:49 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Made my own last week. 4 pucks - Dicks Sporting Goods $8.50, hardware from Ace Hardware $9.50.
Took about 20 minutes.
Here's a youtube vid, not me!!! But it gives you an idea of what to do.
Old Jun 20, 2013 | 11:40 PM
PeterB's Avatar
PeterB
Pretty cool. Those rails look like they have to go on the bucket list for another purchase soon.
So guys I have a rotor/pad install coming up this Sunday... The mechanic that is doing it is not Chevy Vet Dealer, just regular mechanics at the local auto repair shop. I would think they know what they are doing but an ounce of prevention is worth a pound of cure! Am I to understand that of they place it on a lift they may damage something on the body? Does it positively without question need this puck stuff or can the Vet cautiously be lifted without causing damage? That's all I need to really break my heart the guys un intentionally damage or crack the fiberglass or something.
What do you guys think? Thank you.
Old Jun 20, 2013 | 11:43 PM
Kmcoldcars's Avatar
Kmcoldcars
I must be really cheap. I cut out some circles from some sheet rubber I had laying around that just fit into my low profile jack. I stacked enough of them so they were a little higher than the edge of the cup on the jack and glued them together. It works great. My car is low enough that the low profile jack will barely fit under the rocker panel. With pucks in there it would never fit under.
Old Jun 20, 2013 | 11:46 PM
Kmcoldcars's Avatar
Kmcoldcars
Originally Posted by PeterB.
So guys I have a rotor/pad install coming up this Sunday... The mechanics that are doing it is not Chevy Vet Dealer, just regular mechanics at the local auto repair shop. I would think they know what they are doing but an ounce of prevention is worth a pound of cure!
Do not assume they know how to correctly lift the Vette. Be there and show them just where they need to lift it and what they need to be careful of. Get them to note there is no damage to the rocker panels before they lift it and check the rockers carefully before you drive off with the car.
Old Jun 20, 2013 | 11:47 PM
jornahow's Avatar
jornahow
I have these too, but I also have the hight density plastic rocker savers from Elite Engineering; (they have saved me from damaging my rockers several times) I think Mr. Bill has the right idea - combine both of these into one unit. If I were starting fresh I would choose the ones that Mr. B has.
To Jacking Puck advice
Old Jun 20, 2013 | 11:53 PM
Choreo's Avatar
Choreo
I have the Elite Engineering frame rails installed as well, but even then I never let anyone put the car on a lift without me there to verify they are positioned on the lifting pad portion correctly. Certain types of lifts will not hurt the car, but others can. The frame rails are cheap insurance.
Old Jun 21, 2013 | 12:02 AM
dblerman's Avatar
dblerman
I made a set out of hockey pucks. But I misplaced them over winter and in the meantime I've just been using a few pieces of 2x4 cut into a square. I just place them between the jack and the frame, works fine.
Old Jun 21, 2013 | 12:03 AM
VETJAZZ's Avatar
VETJAZZ
Buy the orange practice pucks. They're firmer and heavier.
