Another vote for these. One of the first things I purchased after the car. Used them numerous times for jacking and have only "slid" on them once on a speed bump I mis-calculated. Glad they were there.
QCVette, I don't think one should us a jack anywhere but at designated jacking points.In between the side jacking points there is not enough support and the aluminum would not be strong enough.I am pretty sure I am correct on this and if I'm not, will somebody let me know.
Fred
I haven't had to jack up my car with it in 5 years, But I would think you can jack it up anywhere, They have saved my *** a number of times on speed bumps, They hang about maybe a half inch lower than the rockers, You can't see them unless you get down and look under the car. They mounted with 3 or 4 large screws per side.
Fred
Thanks for the info.
These rails look like a good thing. I have put them on my list. Maybe my birthday present next month, who knows?
I thought about going this way, Buy I thought if you hit a speed bump just right it could shear the puck right off.
Both of my rear leave-in jacking pucks snapped like twigs on a shop's lift as they were backing it off. They're very convenient, and they hold up well unless they hit something immovable, but I'll be looking at the frame rails sometime in the near future to replace the pucks.
I've already used them once to jack the 99 C5 up to change the oil, and had no issues. Another set is going on the 04 CE next week. These are pushed in, then you turn them 90 degrees to lock into the frame.
From: Wylie TX --> Less is More, except under the hood !
Go for the A&A frame savers. They don't cover the frame tie down holes. If you ever have to be towed these holes are left open with the A&A rocker rails.
You can still jack the car in the normal jacking locations and do not need pucks. Easy when getting service done at a shop too.
I lift my car every weekend on these rails to clean my car.
And they stick down slightly lower than the painted rocker. So they help to protect your paint.
For the A&A rails I would like to know floor jack placement on the rails. Do you need to make an adaptor for the jack contact to the rail? Is a simple 2x4 sufficient or do you need to modify the wood?
I jack my car up every weekend with these rails and no pucks.
I put my jack on the aluminum rail just beside the fame hole.
The frame rail is bolted to the frame.
No adapters needed.
An auto shop will also jack on the same locations.... front and rear of the frame rail.
Just on the inside of the frame hole.
I would not recommend pucks that are rubber or plastic... They can deform under load, and plastic will eventually break.
Our club machined our own out of aluminum that are a little thicker than the ones you can buy.. but I would recommend metal pucks.
My low profile jack has a rubber disc for the puck to set on so they do not slip..
