[Z06] Tire Idea?
isn't the point of dropping tire weight performance?
really not trying to bust you down on this, just saying, if we list out pros and cons of each, the only place the ps2 wins is weight
I'm not saying the car will be slower with the SS's, clearly that's not the case, however, your car may be faster with the PS2's.
Even a reduction of five pounds per corner, unsprung rotating mass, will multiply to better performance than five pounds otherwise, sprung mass.
Thus, the performance of the car will be better. Rotating mass, not simply weight.
If you move to a heavier tire, that's ok, certainly not ridiculous, because the tire will still be far greater than average.
whole question would be if the better compound of the pss could outperform the lighter ps2
wheel and tire combined you would probably be looking at 5lbs difference per
The answer is, selection that concludes with the results being on target with the car. Thus lighter more agile performance may be better than better than average performance because of utilization of greater factors.
I'm not saying the PSS's will be slower than the PS2's, probably no almost always, however they are heavier, this factor alone makes them worse for tons of implementations.
i still think the pss would win but you would be looking at 5lbs per corner weight saved on oem/ps2 vs something like a nurburgring/pss combo
wheel weight is the single most important place weight matters on a car
this is direct from michelin on the two tires
