[Z06] Door locks
Old Jun 28, 2013 | 07:05 PM
O3 animal's Avatar
O3 animal
Default Door locks
Ok only my driver side door will not lock or unlock with key fob can use key to open but not fob also when car hits 10mph auto lock works what can I look at thanks
Old Jun 28, 2013 | 08:35 PM
C5Conrad's Avatar
C5Conrad
I have the same problem. My passenger door will lock but not unlock with the fob or button in car. This doesn't happen all the time.
Someone help us.
Old Jun 28, 2013 | 09:16 PM
bluestreak63's Avatar
bluestreak63
Try getting a new battery for the fob. My fob for my DD was acting strange...changed the battery, all was well...
Old Jun 28, 2013 | 09:20 PM
C5Conrad's Avatar
C5Conrad
Mine also will not unlock with the button in the car. Not all the time though.
Old Jun 28, 2013 | 09:41 PM
LSxFTMFW's Avatar
LSxFTMFW
I have the same problem, drivers side locks, but wont unlock with the FOB.
Old Jun 28, 2013 | 10:20 PM
O3 animal's Avatar
O3 animal
Ill try battery's but mine won't lock or unlock.
Old Jun 29, 2013 | 09:59 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Door lock relays.
Old Jun 29, 2013 | 10:24 AM
O3 animal's Avatar
O3 animal
Each door have their own? Where are. They located?
Old Jun 29, 2013 | 10:36 AM
SJSZ06's Avatar
SJSZ06
There is a control module in each door that contains the relays.
Two relays control the lock/unlock and there is one for the window.
The relays can be purchased thru DigiKey corp. They aren't expensive.
Plus the specs are better than the originals - they should last longer.
Sorry, I don't remember the part numbers...
I have a link to an old how-to post, but it doesn't seem to work anymore. Says I don't have permission to access it. I guess they moved it to some sort of archive.
It's a shame, that was a great post and I think it should be a sticky since there are so many posts about this problem.
It was this link: http://forums.corvetteforum.com/c5-g...w-problem.html
Old Jun 29, 2013 | 03:48 PM
ZeeOSix's Avatar
ZeeOSix
Here's a similar thread that still works and might have some good info on how to replace the relays, etc.
http://forums.corvetteforum.com/c5-t...direction.html
To Door locks
