No more column lock issues
Old Jul 12, 2013 | 03:53 PM
dcandel's Avatar
dcandel
Oldtimer
Default No more column lock issues
I started getting the dreaded column lock problem a few weeks ago so I ordered an LMC5 to fix it. Fortunately I didn't get stuck anywhere, the 4 or 5 times I got the "pull key" message, I was able to get it going by pulling the key & restarting it 5 or 6 times each time it happened. I talked to the Service Manager at my local Chevy dealer and he told me that the recall wasn't done on my car (it's a 99) & to bring it in. So they fixed it under the recall and it works great now. No more worries.
Question: Should I still install the LMC5?
Old Jul 12, 2013 | 04:18 PM
Cybermind's Avatar
Cybermind
Originally Posted by 8VETTE7
ABSOLUTELY install it. The GM repair is NOT a permanent fix. If you go with just the recall fix, it WILL fail again.
I hate to break it to you but you would've been better off without the GM recall. It will fail and you will need to remove it in order to install a proper CLB in its place. I'm not sure if the LMC5 requires removal of the GM recall.
GM completely dropped the ball when it comes to C5 column lock problems and fixes.
Old Jul 12, 2013 | 04:47 PM
dcandel's Avatar
dcandel
Oldtimer
According to Compliance Parts website, the LMC5 can be installed even if the recall has been done.
Old Jul 12, 2013 | 06:05 PM
Chilliwack vettes's Avatar
Chilliwack vettes
Originally Posted by dcandel
question: Should i still install the lmc5?
Absolutely!!!
Old Jul 12, 2013 | 09:41 PM
Cybermind's Avatar
Cybermind
Well there you go! Then you have no problem. Just make sure you do it.
PS: if it were me, I would still remove the GM K-harness (recall). I just wouldn't like the thought of having an electronic component under my dash that will eventually fry.
Old Jul 12, 2013 | 09:49 PM
I would never let the dealership do the repair to the column lock. Their fix just doesn't stand up over time. Install either the LMC5 or a column lock bypass kit and not worry about it again.
Old Jul 13, 2013 | 02:16 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
You did such a crazy thing after being a member here for 8 years and 600 posts?
Old Jul 13, 2013 | 09:35 PM
Sids04's Avatar
Sids04
The LMC is such an easy install.. You'd be crazy not to.
To No more column lock issues
