Euro tail lights problem
Old Jul 17, 2013 | 07:58 AM
chuckeb84's Avatar
chuckeb84
Default Euro tail lights problem
These were installed on the car when I purchased it.
Hazard flashers work...light up all 4 yellow.
Driving lights work all red
Trunk 3rd stop lamp works when brake applied..
But the brake lights don't
Is there a place to get started on trying to find a fix.
Wires and connections seem clean and tight.
Old Jul 17, 2013 | 09:34 AM
chuckeb84's Avatar
chuckeb84
Old Jul 17, 2013 | 09:36 AM
chuckeb84's Avatar
chuckeb84
Lights Rt Passenger
Old Jul 17, 2013 | 09:38 AM
chuckeb84's Avatar
chuckeb84
Old Jul 17, 2013 | 09:39 AM
chuckeb84's Avatar
chuckeb84
Old Jul 17, 2013 | 09:43 AM
chuckeb84's Avatar
chuckeb84
Lights Rt Pass to left driver side.
I don't know why this kit required cutting of wires on the back end instead of just the one white under the dash?
But the bulbs look good.
Everything seems to work except the brake lights.
Old Jul 17, 2013 | 10:37 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I think the cutting of the wires on the back is your problem. I ran euros with the harness and only had to cut the white wire under the dash. Everything else was plug and play. Try crimping those wires back together and see what happens.
Words to the wise for anyone considering this. Leave enough room underneath the dash when you cut the wire, meaning cut it in the middle and not near the top of the harness switch. This leaves you enough wire to work with on both ends when (if) you ever want to rewire or crimp it back together like I did when I upgraded to LED halos.
Old Jul 17, 2013 | 10:47 AM
JetMechZ16's Avatar
JetMechZ16
It could possibly be something in the Hazard lights switch. I've read that power to the brake lights is routed through this switch. Not sure if that includes the 3rd brake light or not. Do a search on the hazard light switch and the brake lights not operating, you should find alot of info and threads associated with this.
Old Jul 17, 2013 | 02:56 PM
chuckeb84's Avatar
chuckeb84
Does someone have pics of the normal setup.
I may just go back to stock.
Old Jul 17, 2013 | 03:03 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
did they work when you purchased it?
Old Jul 17, 2013 | 03:28 PM
chuckeb84's Avatar
chuckeb84
Reconnected green wires on rt side.
Brakes work.
Right side flashers and turn signal doesn't.
chuckeb84's Avatar
chuckeb84
I doubt it now!!!
Old Jul 17, 2013 | 04:48 PM
chuckeb84's Avatar
chuckeb84
This was I Mid America kit...not plug and play...
Old Jul 17, 2013 | 05:46 PM
chuckeb84's Avatar
chuckeb84
Now everything works fine.
i disconnected the green wire that was previously disconnected and all lights in all conditions work.
Maybe it is the emergency flasher and not my imagination??
Is there a way to test the flasher or just remove and replace.
No error codes.
Old Jul 17, 2013 | 06:20 PM
chuckeb84's Avatar
chuckeb84
Do Hazard Flasher lights or the switch impact brake lights?
Old Jul 18, 2013 | 07:40 AM
dadaroo's Avatar
dadaroo
Will try to assist at your request.
What year is your car?
Was it a Domestic that someone modified to have Export tail lights?
Confused on your last posts: Exactly what is not working now?
Do you have any info on the wiring mod? If not see is if Mid America can provide.
Old Jul 18, 2013 | 07:45 AM
chuckeb84's Avatar
chuckeb84
I did finally get the info for installation.
This kit does require cutting wires and spade connectors.
I'm going to assume the lights were working.
Then at some point only third tail light worked.
After taking everything apart and reconnecting, the lights work today.
Nothing was obviously loose or faulty.
So possibly the problem is the hazard switch.
All lights now working. For now.
To Euro tail lights problem
Old Jul 18, 2013 | 07:46 AM
chuckeb84's Avatar
chuckeb84
Has added on euro lights by previous owner.
Old Jul 18, 2013 | 08:20 AM
dadaroo's Avatar
dadaroo
Exports do not have a hazard switch. I assume when they hacked your Domestic wiring, the hazard switch was left in the circuit. If this is true, I am sure the 4 brake lights still go thru the hazard switch but the "3rd" center light does not. If you are having only the
3rd light function occasionally it would seem that the hazard switch is the cause. If you send me the info you got I can confirm your wiring.
Properly removing the hazard switch is a PITA. I bought the Hyper Flash bypass unit which is easy to install.
Old Jul 18, 2013 | 11:57 AM
dadaroo's Avatar
dadaroo
PS: If you decide at some point you want to return to original I can send you the wiring schematics. Sorry about the "hacking" comment, but when I looked at the quality of the work, that is what came to mind.
