Purchase Advice
Old Jul 20, 2013 | 01:03 AM
dig540's Avatar
dig540
Default Purchase Advice
Hey guys, recently sold my MKIV Supra and i've been looking to get in the vette community, i've been searching for weeks for an FRC with mods. I went today and checked out a local car it's VERY clean and runs strong. The owner has only owned it for 3 months and says he really wants to get into a z06, also the previous owner did ALL of the modifications and never sent over the receipts/paperwork, so there is no documentation...he is asking 19k as it sits....any advice would be appreciated. Build sheet he sent me attached below, owner that did all of the work is a senior member Wicked99 is his username. I've done my homework and went back and looked through the previous owners posts, and it seems from reading the posts that the work is legit...apparantly his c5z got caught in a flood...he picked up this FRC and basically swapped the entire chasis/drivetrain/suspension into the FRC. Advice would be appreciated
1999 FRC w/Z51 package, Pewter w/Targa top conversion (Halo black)
has all Zo6 vents and grills.
Car has 152,000 Only 30,000 miles on the drive train since built.
Oil change (Mobil 1 syn w/Mobil 1 Filter)(Just done 3/16/2013)
Motor -
408 ci 10:5.1 compression 470 RWHP 478 RWTQ== Tuner /Scott 205-266-0413
LQ9 iron block that has epoxy coating
Eagle Forged Crank
Eagle H-beam rods
JE Forged Pistons
Ported hi volume oil pump
Duel Roller timing chain
Comp cam 228/232 - 595/602 - 115+4
CTS-V roller lifter
Comp Cam One piece push rods
WCCH Stage II P&P L92 Heads Duel Springs for 650 lift
ARP Head Bolts, cam bolts
SLP Underdrive pulley
L76 intake w/P&P LS2 TB
New LS3 injectors, adapters and harness plugs (1-08-2013)
Vararam B2 AIR intake w/85mm MAF and vararam air bridge
New NGK plugs and GMPP Red Plug Wires (done 12/25/2012)
Rev-X-treme Oil Catch Can
New radiator (11-28-2012)
New starter (1-17-2013)
Ploy Motor mount added to Passanger side (have the driveside to go with)
Racetronix fuel pump and harness upgrade
line loc
Exhaust-
1 7/8s LTs w/ full 3'' exhaust and 3'' X-pipe to factory Z06 titanium cat back w/ duel ele-cut outs.
NEw NGK O2s
Transmission, Torque tube and diff -
RPM Stage 5 6-speed transmission
Torque Tube has ECS Driveshaft replacement
Diff is 3.42s with hardened shafts
Spec Stage 3+ clutch w/speed bleeder line
Tick Performance Master Cyl
2012 Zr1 shifter that has 1 1/2'' cut out to shorten
DTE Transmission/Diff Brace
Suspension -
Factory Z51 springs
2011 Z51 sway bars w/metal end links
Bilstin HD Shocks
Prothane Poly bushings in the A-Arms (just done 2/28/2013)
4 Brand new wheel hubs (just done 2/28/2013)
Aftermarket 3/8 ths transmission tunnel plate (coated to reduce heat in cabin)
Z51 power steering cooler
Brand new inner and outer Tie rods (Done 3/17/2013)
4 Wheel alignment (3-18-2013)
Brakes-
Slotted Front and Rear
Semi metalic pads
Calipers painted Red
Interior-
Black Sports seats (not an option for the FRC)
New foam for the seats and new bladders for the driver seat lumbar
Add seat heater (Driver) (done 2/5/2013)
HUD cluster Added (Not a option on this car)
Partition to close off the trunk from the cabin
MP3/ipod hookup
Power windows/locks
a/c in great working order
Factory bose stereo
Raptor Shift light
Wheels-
CCW 505a's 18x10 front with 275-35-18s and 18x11.5 rear with 335-30-18s.
Exterior-
Caravaggio Rear Spolier
Lower rear valanvce painted black on rear bumper
Tinted windows
New HUD Windshield w/new weatherstriping and A-piller pieces (3-21-2013)
Complete Professional Detail (Buff, Polish, Wax, Steam cleaning, Inside & Outside, Dressing) (3-20-2013)
I know there is some stuff that im for getting.
Old Jul 20, 2013 | 01:31 AM
rrichar2591's Avatar
rrichar2591
I realize the drive train only has 30, 000 miles but 19, 000 for a 1999 FRC with over 150, 000 miles on the rest of the car seems a little high. I see your looking for a car that has been moded so only you can decide how it meets your wants. Good luck.
Old Jul 20, 2013 | 01:33 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I agree... I wonder how many parts on the car now were in the flood?
Old Jul 20, 2013 | 06:03 AM
Just my opinion, but I wouldn't pay $19K for a car with 150K miles on it. But it does have a lot of good mods and if that's what you are looking for, then best of luck with your decision.
Old Jul 20, 2013 | 06:25 AM
oldschoolvette's Avatar
oldschoolvette
I would definitely gather some more information but this could be a nice car.
The problem is that once you jump of into mods and start spending money it gets expensive in a hurry
maybe contact the builder and get some first hand INTEL
good luck
Old Jul 20, 2013 | 01:03 PM
racebum's Avatar
racebum
car isn't going to sound like it's worth anything on paper
if he's really gone through the whole car and has proof of it and you want a built car like that it may be worth considering an offer
no way you could buy an frc and build it with those parts and come anywhere near the teens.
so, if that's what you want, i'd chat
friend of mine just paid 30k for a turbo c5z with 60k on the body
Old Jul 20, 2013 | 01:49 PM
strand rider's Avatar
strand rider
I guess I am more cynical than most here, perhaps it is my auto insurance background, or it could be the time spend in retail sales. Money makes people do funny things, and some folks are ethically challenged anyway.
So a guy loses his car to a flood. It now has a salvage title. Another ,or the same guy, decides to salvage some parts and put them into a car with a clear title. Parts are now able to be represented as being more valuable.
Could be true, the parts could be worth running. I am not expert on flood damage, I am more familiar with salt water corrosion. I would be very concerned if it was under salty water for any time.
I can't tell you the value of this car. Some might call it a deal , others a Frankenstein car. I am justly paranoid about all the slick people selling used cars, because my used car skill level is low. My market place skill is very good, which accounts for the paranoia about this deal.
It's your money, at my skill level I would be unable to answer all the questions about this car. Hopefully, you know enough about what you are looking at to do better.
I was trying to point out that this could be a perfect setting for someone to sell a pig in a poke. The cat gets out of the bag after you buy it. I can't think of anymore clichés, but the fact that there are some common ones that apply well to this situation makes me pause.
I guess it depends on your money. Some people bet that amount all the time. I would rather be in a situation with less risk, my money is tight, and there are a lot of things to buy in this world.
Gain involves risk, as you know. I bought my car on instinct, didn't have time to minimize the risk in the transaction. I also trusted the seller, I can read people a little better than I can kick tires. And I can kick some tires, being a car lot veteran.
Old Jul 20, 2013 | 02:54 PM
calvins's Avatar
calvins
Oldtimer
Eric (wicked99) is a member of the forum and did own a 99 pewter FRC. Corvette repair and modification is how he makes his living. That said; I've never dealt with him personally so this isn't an endorsement. Simply passing on pertinent info. PM him and take it from there
http://forums.corvetteforum.com/priv...newpm&u=281162
To Purchase Advice
