Pcv Boot
Old Jul 21, 2013 | 11:55 AM
mikeyrko's Avatar
mikeyrko
Default Pcv Boot
As you can see this piece needs replacing. From what i've seen its a expensive part as anybody found a work around?
Old Jul 23, 2013 | 12:53 PM
mikeyrko's Avatar
mikeyrko
Maybe I should have posted this in the tech section.
Old Jul 23, 2013 | 01:30 PM
sfc rick's Avatar
sfc rick
Mine deteriorated too, so off I went to the local auto parts store and bought a solid rubber bushing large enough to trim and cut down to hold the PCV valve. Then after I inserted the valve I took black electrical tape and wrapped it, then applied that liquid tape in a can on it and let it dry.
Just use your imagination and figure on spending about $10.00 at the parts store.
By looking at your pic, I would degrease it let it dry, then wrap electrical tape around it(a bunch) then coat it with liquid electrical tape.
Old Jul 24, 2013 | 10:12 PM
OUFAN76's Avatar
OUFAN76
In case you haven't already, be sure to check other rubber parts of the pcv harness. There are 2 elbows that go to the valve covers, and a Y fitting behind the intake manifold. They've been in there just as long as the one in your picture, and they're prolly in the same shape. The Y fitting is hard to see.
To Pcv Boot
