Reset AC
Old Jul 29, 2013 | 01:28 PM
Black76's Avatar
Black76
Default Reset AC
How do i reset the AC the driver side is blowing cold air and the passenger side is blowing hot air i seem to remember pulling some fuse to reset the blowers is that correct
Old Jul 29, 2013 | 01:32 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
you could just disconnect battery for a bit...
Old Jul 29, 2013 | 05:33 PM
ktlocklear's Avatar
ktlocklear
So this is common? Why does it happen?
Mine did it the other day for the first time, except the driver side was hot and passenger side was cold. I rotated the temp control **** on the driver side all the way to HOT, waited a few secs and then turned the **** all the way to COLD. Took care of the issue, and it hasn't done it again since.
Old Jul 29, 2013 | 07:25 PM
pewter99's Avatar
pewter99
common ....yep.....several possible reasons....most common is the actuator door gears are worn...not as much of an issue in the 01 and up as they added some logic in the head unit to compensate for the issue
Old Jul 29, 2013 | 07:38 PM
Ronnie wilkins's Avatar
Ronnie wilkins
Mine was hot also on driver side. Had no codes so I got the gauges and gave it a shot of R138a and it is fine. Hard to believe just being a little low in refrigerant can make one side blow hot and the other is fine but it does. Has to do with a divider in the box or something.
Old Jul 29, 2013 | 08:20 PM
RMB97LS1's Avatar
RMB97LS1
I thought the actuator controlled the air flow. Mine for example blows great out of the pass side, but just a trickle out of the drivers side. Both sides cold though..
Maybe I'm just confused..
Old Jul 29, 2013 | 08:32 PM
This might give you some ideas.
To Reset AC
