[Z06] active handleing question
Old Jul 31, 2013 | 12:30 AM
jbp8653's Avatar
jbp8653
Default active handleing question
Hello all! Was driving home last night on the interstate going about 65 mph, no rain, and all of a sudden for no reason the active handleing cycled on for a split second. Was not long enough for the car to react in any way. About 1/2 mile down the road it did it again. Got worried because I have heard stories about stuff like this happening out of no where and people losing control of the car. I turned it off for the ride rest of the way home. What could it be? Bad sensor? ecm? The car is a 02 Z06, 115k, Thanks for the help
Old Jul 31, 2013 | 03:35 AM
HBbadb0y's Avatar
HBbadb0y
Did you feel a jolt when it came on? It happened to mine. It was a failing steering wheel positioning sensor.
Old Jul 31, 2013 | 09:26 AM
jbp8653's Avatar
jbp8653
No jolt but it seemed like it was right on the verge
Old Jul 31, 2013 | 02:00 PM
tlove32's Avatar
tlove32
I had the same problem - I felt a slight shimmy in the steering wheel, then the msg on the DIC appeared. About a week later, the system went completely bizerk, locked the d/s front brake and almost sent me into a highway divider. I had the steering wheel position sensor replaced, and all has been well.
Old Jul 31, 2013 | 09:07 PM
Moto One's Avatar
Moto One
Too. Steering position sensor (2hr DIY) problem fixed.
Mark
Old Aug 1, 2013 | 08:55 AM
amlarson2001's Avatar
amlarson2001
SPS for sure. Same happened to me. Also makes it so your cruise control wont stay engaged. That's the part that drove me nuts.
Old Aug 1, 2013 | 01:44 PM
jbp8653's Avatar
jbp8653
Thanks for the help. Will check out SPS for sure. Dont need to go on any joy rides.
Old Aug 1, 2013 | 05:59 PM
RedZMonte's Avatar
RedZMonte
Steering angle sensor (common in a few of the GM's).. My Bonneville had a simmilar issue and ended up being a Yaw sensor (funny enough the replacement part number is the same as the vette). both are Likely scan tool should tell you.. If you can unhook the Yaw sensor for now that should disable the cars stability system to let you drive it without worrys... not sure where they hide them on the Vette, but thats what i did with my bonnie.
S
Old Aug 7, 2013 | 09:43 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Peace
Chip
__________________
..................Click for
To active handleing question
