Yes, probably! You may want to study up and search "ignition switch". When it goes, the car stops as though you ran out of gas! It will crank and maybe sputter a bit but that's it. I guess we can add it to the lists of bum parts on our Vetts. Like the steering column lock or the multifunction switch it seems like most of us will be struck with this mine at 68k. Just hope you are close to home like in my case. Bill Curlee was a great help in helping with the diagnosis and has a good tutorial on this where you can actually fix the switch by cleaning the burnt contacts. Mine had quite a few burned ones which I did not bother to clean, and just replaced it with new from my local auto guy for $72. Not a real tough job especially if you had your dash covers apart before. You may as well replace your flasher switch at the same time (another common Vette part to go). Good luck, and thanks Bill Curlee!!
Yep, happened to me. I was a couple of miles away and a "Reduced Engine Power" signal came up on the DIC. Most speed out was around 5mph and barely made it up into my garage. Funny thing is it comes and goes. Took some searching to identify the problem and sure enough the brass contacts were in pretty bad shape. Changed out the back part of the switch and all is well for now.
Took care of this one before it became a problem. It was a good thing too because 4 of the 6 contacts were burned pretty badly. I sanded down the contacts and gave them a little bend to improve the connection and rebuilt the switch. Now it works as if it were new.
Just one of the many things Bill has helped us out with over the years.
yep mine would die when I stopped at a light or turned to the left. Did some reading here and took it out and cleaned it just to make sure that was the problem. Cleaned it and it's been fine ever since, I think that was a little over a year ago. If it happens again I'll just swap it out and keep the old one and clean it for a spare.
Mine always started right back up though.
Exactly how long have they been making ignition switches?
Can someone do a poll on this? It would be good to know how many C5 people have had this problem. It appears there are lots! This must be like: the crummy HVAC display, the headlight motors, the window motors, the multifunction switch, the four way flasher unit, the air pump check valve (behind the engine), the oil pressure switch (behind the engine), etc. I probably left several off; if I didn't do most of my own work, I could not afford to keep my car, but I still like it, go figure.
Everyone has this problem. Those who haven't done the preventative maintenance just don't know it yet. The ignition switch is just built in a way that eventually the conctacts will be burned so badly they'll no longer conduct electricity. Those of us who have already suffered from the problem or have performed preventative maintenance to keep it from happening know exactly what those owners have in store for them sooner or later.
I like a good McGuyver as much as the next person, but I have to ask: given that the labor/parts ratio on this job is so high, is it really worth $80 not to put in a new one?
I know $80 isn't exactly sofa-cushion change, but it's dirt-cheap compared to some of the $$$$$$ stuff we buy for these things.
What labor/parts ratio? It takes about 10-15 minutes to get to the part; another 15 to take it apart, clean & fix it, and put it back together, then another 10-15 minutes to reassemble everything. That's about a 30-45 minute job with no expense except a tiny piece of sandpaper and no need for new parts. Why spend money on this when you can save it to buy another one of those $$$$$$ parts?
I'm reading the Bill Curlee tutorial linked upthread, and it looks like the whole IPC comes out. If it's really a 15 minute job to remove/replace, forget what I said.
I guess it would really depend on how familiar you are with taking apart the center console, radio bezel, and other associated interior parts. I've had mine out and back in quite a few times so I do admit that I can probably do it a lot faster than someone who has never taken them apart before. Even so, it's not a huge job and it's good experience.
I put a new stereo head unit in, took maybe an hour start to finish for a first-timer. On paper at least, this looked like it went quite a bit deeper, for lack of a better word.
I thought it was going to be a huge job myself; I think the detail Bill put into the entire process makes it seem more lengthy than it actually is. Going by your stereo install you'd only be looking at a few more screws to take out to remove the remaining dash sections so you can get to the switch.
