[Z06] Ashtray question!
Old Aug 6, 2013 | 04:39 PM
JoeDubya's Avatar
JoeDubya
Default Ashtray question!
Hi all. My secondhand C5 Z06's ashtray, the little pullout under the
swingup panel in the lower front console, was apparently glued in,
and just popped out. Can someone show me a picture of the inside
of the hinge of this pullout? Does it have a spring to keep the
door closed or open?
thanks!
Joe
Old Aug 6, 2013 | 07:54 PM
bumble-z's Avatar
bumble-z
Yes there is a spring.
You will see two small holes/slots across from one another,thatis where each end of the spring goes into.
Old Aug 6, 2013 | 08:07 PM
JoeDubya's Avatar
JoeDubya
Here's a picture of mine, and the spring out. If you can show me
a picture of how the spring is supposed to go, I'll try to do it.
I don't see any slots for it...
Old Aug 6, 2013 | 08:57 PM
cadwiz_01Z's Avatar
cadwiz_01Z
Veteran: Marine Corps
From: When Democracy becomes tyranny, the armed citizens will still get to vote!
Mine is hinged open.
Old Aug 6, 2013 | 09:09 PM
bumble-z's Avatar
bumble-z
Appears you need the small diameter rod & your good to go.
Old Aug 6, 2013 | 09:16 PM
JoeDubya's Avatar
JoeDubya
thanks everyone!
To Ashtray question!
