Radiator coolant Filter
Old Aug 10, 2013 | 02:15 AM
geocor2003's Avatar
geocor2003
Default Radiator coolant Filter
Saw a few on ebay,it seems like a good idea, it only $9.99.Just cleaned my radiator tank ,& it was a little dirty with debris,from the Dexcool.A screened filter may eliminate some of this?You can remove & clean this filter screen periodically.It fits on our hoses,top easiest.It should fit our 1 1/4 ID hoses.BTW Does the coolant flow from the top hose ,from the engine to the radiator?
Old Aug 10, 2013 | 06:34 AM
killain's Avatar
killain
Oldtimer
Default Coolant filter ?
The only thing you need to do to keep your cooling system in perfect shape is flush out the old Dexcool and install fresh coolant every five years. Installing a filter is only going to slow down the flow and you really don't want to do that. Old coolant gets dirty and if left in there too long you'll get a sludge buildup. Don't go installing filters or anything but good fresh new coolant.
Old Aug 10, 2013 | 07:27 AM
andrec10's Avatar
andrec10
Sounds like Snake Oil to me!
Old Aug 10, 2013 | 08:21 AM
Not something I've ever heard of nor a part I would install on my car.
Old Aug 10, 2013 | 08:31 AM
RedC5's Avatar
RedC5
I drill pump out my overflow tank every year to keep some freshness in the coolant. This is real easy to do.
Old Aug 10, 2013 | 10:48 AM
Loby 1's Avatar
Loby 1
I switched over to green and will flush every 2 1/2 years.
Old Aug 10, 2013 | 01:06 PM
geocor2003's Avatar
geocor2003
http://www.ebay.com/itm/221227278063...84.m1423.I2648
Not an oil but a large filter,that has a capacity that will not clog easily!
To Radiator coolant Filter
